Question about Casio Parts Cash Register PC Desktop
PCR265P CASIO CASH REGISTER ERROR CODE E 94
CANT GET IT OPEN.
  • Casio Master
  • 1,648 Answers
You have a printer fault. Check to see if it is jammed.
If anyone is having trouble programming a Casio PCR265P, the manual is here:http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-265P_users_manual.html
Posted on Dec 12, 2012
flexion1
  • 737 Answers
SOURCE: a error in cash register casio ce-4250
Hi.
Try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down.
Turn power on at wall.
When you see 'FFFFFFFFFF' on display, let go of RECEIPT FEED.
Press SUBTOTAL
Let me know if you still have trouble.
Mark
Posted on Jan 19, 2009
flexion1
  • 737 Answers
SOURCE: error code Eo2
HI.
Error 2 means no clerk code entered. You need to log on to the machine with your clerk (PIN) number, then press the CLERK or CLK# button. Then it will let you make sales.
If you have trouble, just let me know.
Mark
Posted on Oct 12, 2008
  • 202 Answers
SOURCE: CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Posted on Feb 22, 2009
SOURCE: E94 code
I personally don't know. But try this. Go to the casio site probably www.casio.com, and try to download a manual, or google casio(use model number)+manual . no spaces in the search. Most times I have had good luck with this method. It works with older faxes, phones,etc. good luck
Posted on Jun 17, 2009
dnewcombe1
  • 1564 Answers
SOURCE: how do i clear an error code on a casio cash register?
Not positive, but I think you have to unplug the unit for 5-10 seconds then plug it back in. Some require a certain key position and operation of certain buttons to clear the codes.
Posted on Jul 24, 2009
I have a PCR-265P and an E94 error
You have printer failure. Check for any paper jams in the printer. Otherwise, the printer may need replacing.
If anyone needs a manual for a Casio PCR265p, try here:
Jul 07, 2012 | Casio Parts Cash Register PC Desktop
I need a manual for casio cash register model pcr265p
Try this link:
http://www.casio4business.com/sa/products/downloads/manuals/other_models/PCR265PB_E0203A.pdf
Jul 13, 2011 | Casio Office Equipment & Supplies
My casio PCR-265P is showing two taxes how can I stop it I only want it to show tax 1
Go into department programming and set the departments to only use tax1.
If anyone needs more information, the Casio PCR265P manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-265P_users_manual.html
Jul 03, 2011 | Casio Parts Cash Register PC Desktop
Error 94 ?
Casio code for printer error. If you want to try servicing it, there may be a service manual here: http://the-checkout-tech.com/cashregisters.php
Mar 06, 2011 | Casio Parts Cash Register PC Desktop
Cash register will not accept new role of paper, when trying to fix it I must of hit something now the roller won't spin and 'error 94' pops up.
For Casio 110/120/130CR E94 = Printer Problem
Normally there are something "stuck" inside the printer or paper feed assy spoilt.
Jul 10, 2009 | Casio Parts Cash Register PC Desktop
E94 code
Jun 17, 2009 | Casio Parts Cash Register PC Desktop
How do i set the tax for retailing for casio PCR265P
Hi. You will need to be more specific. I have no idea what your tax system is. It is very complicated and normally a dealer would set it for your area. However, if you can tell me your tax rate(s), whether you use add-on, add-in, table tax, or tax on tax, and how your tax breakdown is recorded on the receipt, then I can help you further.
Mark
Dec 12, 2008 | Casio Parts Cash Register PC Desktop
Casio PCR265P error E94
CASIO support like please try 800-633-5586 or 973-361-5400 ext 4434
Nov 13, 2008 | Casio Parts Cash Register PC Desktop
Error code Eo2
HI.
Mark
Oct 12, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
213 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
