Question about Kenmore Elite 45986 Front Load Washer
Not responding to anything!
My daughter tried to cancel the wash cycle midway, and I don't know what she did, but the door is unlocked and won't lock, there are clothes sitting in water in there. It's blinking 12 minutes left, but won't responde to anything! I have held down the pause/cancel button numerous times, I have tried to lock the door so I could drain it, but it won't lock. I have tried getting it to restart, it won't do that. Please help!
  • 66 Answers
Unplug it for 30 min to reset some time 2 hours. It has a computer in it That is like rebooting.
Posted on Jan 14, 2009
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Lg washing machine WM2277HW takes spells where door won't open at end of cycle.
try to replace the latch, go www.repairclinic.com and buy online.
God bless you
Jun 19, 2012 | Washing Machines
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Stove door will not open after cleaning
does the oven respond to any controls??? or is it dead??? if it responds, id try to restart a clean cycle, this will attempt to lock the door if it does, then in a few seconds cancel the cycle and the door should unlock. or you can can try to disconnect the power to the unit for a few min and upon restoring power the first thing most ranges do is to self check there latches.
Apr 03, 2008 | Kitchen Ranges
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Door Locked after FA code
Press "end of cycle" button and wait for a click or 3 minutes, they try the door. Do not force door
Dec 28, 2007 | Whirlpool GHW9300 Duet Washer
Kenmore Elite 45986 Front Load Washer Logo
83 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
