XPS M2010 BUILT IN SPEAKERS STOPPED WORKING - Computers & Internet
  • 7,627 Answers
Have you updated your OS? Is it muted? Is the volume up? Is the audio driver installed? Is the audio device enabled? Are headphones plugged in?
Posted on Dec 12, 2012
4 Suggested Answers
ArmenianTech
  • 24 Answers
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Posted on Oct 08, 2009
SOURCE: i have a xps m2010 laptop.. lights flashes but
Contact Dell and get a replacement Video Card
Posted on Mar 11, 2010
  • 97 Answers
SOURCE: XPS M2010 boots in and everything works but fans
You can try installing this program that controls the fans on a Dell laptop. If this does not work you have a hardware issue with either the fans or the main board.http://www.diefer.de/i8kfan/index.html
Posted on May 30, 2010
I have Dell XPS M2010. Windows Vista 32 bit. 350 bluetooth module The mouse connects and works well. The keybboard won't pair. I put it into discoverable mode and the three lights next to the power...
The solution is to formn a class action suit against DELL for this overpriced piece of junk. I went through 3 of them and they all failed.
DELL left these dogs out there in the market until the warrenties expired on all the M2010 machines and now they will charge you for their failure to build a solid product.
The Bluetooth Access Icon is nowhere to found in the control panel, so the manual is wrong as well.
DELL is acting irresponsble and needs to be punished. Let's form a Class Action Suit today.
Apr 14, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
May 29, 2010 | Dell Inspiron XPS M2010 Notebook
Hi, there are some vertical red line (Not a solid line but just a group of red dot) On My XPS m2010.It just come from computer starts till it comes to windows. Some says it was a motherboard problem, some...
The M2010 has a separate discrete video card from the motherboard.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=M2010+video+card&_sacat=See-All-Categories
If the dots are not seen in Windows, then it might just be a BIOS glitch (Try flashing to most current)
I'd only bother with it if the problem exists in Windows and the Diagnostics
Jan 22, 2010 | Dell My XPS M2010 Notebook
My dell xps M2010 laptop is not working with the battery but it comes on when i plug in the ac adaptor charger. when i checked the bios setting it says battery not recognized and later, when i turned on...
Hello and thank you for using Fixya's services.
Your power adapter is bad and is not able to charge the battery at all (which is why the battery is dead). Yes, this is common with laptops because of the constant plug in and plug out. Yo can purchase a new adapter for less than $25.00 on eBay. Anywhere else it will cost three times more.
Once you replace the adapter, the battery will get a full charge and you will be up and running again.
Please let me know if you have any questions and I will assist.
Oct 27, 2009 | Dell My XPS M2010 Notebook
Dell M2010 Not booting up.... Craziest dell story to date
Your power supply might not have enough power to feed to your system. Especially if you have alot of components connected to it.
Aug 12, 2009 | Dell My XPS M2010 Notebook
I have lost sound on my Dell XPS M2010
Yep - this I run into every start up, or every awake session from Standby - the problem is that the default sound device changes - I've gone through the control panel, and put a shortcut to the Sound mechanism in my taskbar - then when it changes, I just modify back to the Speakers/Headphones setting - I usually have to change stations on Pandora, or skip to a new Youtube, but it all works our very quickly.
May 29, 2009 | Dell XPS M2010 Wireless Bluetooth Keyboard
How to replace Hard Drive in M2010
just replace then format? if the os is in the old hd, install the os on the new hd then
May 24, 2009 | Dell XPS M2010 Notebook
COOLING FAN DONT WORK ON DELL XPS M2010
call the dell tech 18006249896 they will be the right people to talk to
Jan 12, 2009 | Dell XPS M2010 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
