Question about Dimplex Heating & Cooling
Dimplex CDE2T It refuses to come on - may have inadvertantly entered a timed programme??
How can I obtain a instruction manual for Dimplex DAC-12005?
try www.dimplex.de/en/downloads/installation-instructions.html
Dec 11, 2014 | Dimplex Heating & Cooling
My Dimplex Cadiz 2000w heater has stopped working
The heating element may be open - check that out.
Sep 02, 2017 | Heating & Cooling
What is a legal character?
Where are you asking what you were asking?. On FixYa?.
The FixYa parser refuses to let anyone enter any character (letter, punctuation mark, ..) that is not part of the English alphabet.
I just had a problem with a circonflexe (^) accent. In the opinion of their programmers, any such symbol is illegal (meaning NOT LEGAL)
Nov 06, 2013 | Philips Computers & Internet
Will not record two programs simultaneously
make sure at least one recording is in DR mode
Aug 08, 2012 | Panasonic Dmr-XW380 Dvd Recorder
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
Jun 18, 2011 | Sony Televison & Video
Mitsubishi 2000 Galant GLS Inadvertently refuses to access reverse. Mitsubishi have recently replaced clutch ... no improvement. This is like a complete block on entering reverse, but will enter if...
Check the gear linkages for wear at all the joints and connections. Check for worn or missing rubber or nylon bushes or loose connector ends. Have someone hold the gear shift input into the box and move the gear lever, there should be minimal movement except in the neutral position and then only left to right.
Mar 06, 2011 | 2000 Mitsubishi Galant
Heater has two settings for heat and only works on low setting most of the time.
The reason for this is the overheating sensor has cut in. It may just be malfunctioning or in fact it is overheating. This has been a reoccurring problem not just for Dimplex, but other manufacturers as well.
My best advice is contact Dimplex directly and talk with someone in their tech service dept. You can find their home page by doing a Google search for Dimplex's home page.
Jan 26, 2011 | Dimplex Heating & Cooling
Hello, I have recently moved into a property that has Creda PWE4ZC control panel and electric heaters. Unfortunately there is no paper work on how to programme the this panel to control when the heaters...
The dimplex RXPW4 is the same as the Creda. The manual is at http://www.dimplex.co.uk/assets/product_instructions/RXPW4_Installation_Operating_Issue_3.pdf
Jan 03, 2011 | Heating & Cooling
Dimplex OFC2009TI programmer not working
yeah i now have this problem did you find a solution?
Jan 26, 2010 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
