Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Lamp nearing end of life
We get this message when we turn our tv on and so we replaced the lamp and it still says that and we still have a slight yellowish hue on our screen.
    Problem Solver:
  • 5 Answers
Your best bet is to get a good TV Repair guy out to your house, that has the Sony Service Code Manual for your set. The TV Tech can access your Service Codes and clear that message out, and possibly make some adjustments that can eliminate the yellowish hue.
The yellowish hue could also come from smoking in the house or burning candles. I have 2 friends that still smoke and had the same problem with their Rear Projection Sony set. When the tech took their set apart he found the brown tar & the soot from the candles had covered the lens and much of the lamp area. They ended up getting a new set because of what it would have cost them to fix & clean the old one up.
There are at least 2 or 3 fans that pull air into every Rear Projection set. The air is pushed out the back of the set to keep it cool, so if they are sucking in dirty air, it will cover the electronics very quickly and greatly shorten the life of the set.
This is not as much of a problem for the newer "Flat Panel" (non-projection) sets because they usually do not need fans. They just let the heat rise throu the vents in the top of the cabinet.
Posted on Jan 17, 2009
How does one rid of the "projection lamp is nearing end of life" after an otherwise successful replacement?
Just used the box that came in with the new projection lamp.Take the old projection lamp put it into that box.Put it in the trash recycle bin,that how u get rid of it.
Oct 19, 2010 | Sony KDF-50E2000 50" HDTV
I have a sony kds60a3000 projectin tv. when i turn the tv on there is a message that says "your projection lamp is nearing the end of it's life." Should I order a new one now? how long do you think it...
You should order a new one and wait for the other one to **** out first. The automatic message is to make Sony more money.
Shop around on the web for the lamp.
Some places are 2-3X more than others
Oct 04, 2010 | Sony LAMP BLOCK XL2100U Projector Lamp
Getting a message that my lamp is nearing the end of it's life. I have 4 questions: 1. How long do you think I have until it will burn out. 2. Is there only 1 bulb/lamp that will need to be replaced. 3....
Hi, my same Sony KDF 50e2000 has been giving me the "proj lamp near end of life" message for approx 6 months-and we watch a lot of tv/play wii. I just ordered a repl lamp on line
Sep 01, 2010 | Sony KDF-50E2000 50" HDTV
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Jan 09, 2010 | Sony KDF46E2000 46" Projection HDTV
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
