Question about Hummingbird HostExplorer
Unable to locate ip host gateway hostexplorer
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw]...
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
How can i map my public ip address to th natted ip private?
It's mapped automatically by your ISP, the real question is what are you trying to accomplish?
  • Are you looking to trying to run some type of service, host a web server, ftp etc?
  • Are you trying to enable a remote connection to a PC/server behind a nat router?
  • Are you wanting to configure a dynamic IP? (This maps a host name ex: myhomeserve.somedomain.com to your non static ip assigned by your ISP)
Please comment back so I can help you!
Aug 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Canon IR 1023if; trying to network with buffalo router and two laptops and a wireless desktop. subnet mask 255.255.255.0 default gateway is 192.168.11.1 laptopA 192.168.11.2 laptopB 192.168.11.4 desktop ...
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Shawn
Jan 28, 2011 | Canon imageRUNNER 1023iF Black and White...
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
Whats the problem when my phone says communication host not found
The phone is attempted to contact a Project Server and was unable to make the connection because the Host (server) was not found. The Host Name did get converted into an IP Address, but the Host itself could not be located. Often these messages are indicative of a temporary failure, particular if the host / device was functioning properly and no changes were made, at all, and the internet connection otherwise functions properly.
You may need to contact the phone carrier or the manufacturer for second opinion.
Have a great day!
May 14, 2009 | LG Shine CU720 Cellular Phone
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Cant find my Router ip to do Port forwarding
click on start and click on run
on run open box type in cmd and hit enter
black window will open, type in ipconfig then click on enter then look for the default gateway address, that;s the ip of your router
dont 4get to rate solution
Apr 09, 2008 | Lucent DSLPipe Bridge/Router
Setting up an ELS 16 Terminal Server
Have you tried this?
Step1.
DEFINE NODE GATE1 IP (enter gateway ip here) GATEWAY ENABLE
Step 2.
INITIALIZE SERVER
Oct 11, 2007 | Equinox ELS 16 Terminal Server
Hummingbird HostExplorer Logo
139 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
