Question about Hummingbird HostExplorer
Host explorer unable to locate ip host gateway
How can I open the page
Locate your router. There should be a label which displays your default gateway. The Default gateway displays a number. It should show a number like
  • 192.168.0.1
  • 192.168.1.1
  • 10.0.0.1
Open your browser (Internet Explorer, Chrome, ETC..) Type the default gateway number into the search engine text box on top of the screen press enter or return (mac). The page should now show user name and password. Locate the router and locate the default credentials. For example. most routers requires the user name to be blank and the password is password. Routers very.
About obtaining an IP address. Routers are usually set to option the IP address automatically unless you manually set a static IP address which is not recommended.
Sep 24, 2016 | TP-LINK TPLink TLWA5210G 24GHz High Power...
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
I have a in-home router set up for a smart tv and a roku device for another tv. When trying to open internet explorer all I get is a white screen. Only after having to restart my computer am I able to...
You may want to check your PC is getting an IP address;
From the command prompt do
ipconfig /all
You should see a line which says gateway: 192.168.1.1
If the gateway is blank then your router is unable to issue your PC with an IP address.
Dec 29, 2014 | E-Machines eMachines Desktop PC
Unable to connect to linksys 192.168.1.1 windows xp explorer 8 bing keeps sending to 192.168.1.1 sites
Welcome to Fixya
Lets find out the ip address of the router first.
From Windows pc do this
1 :Press window key ( key between ctrl and alt ) + r
2: On run window type cmd and press enter key
3: On command prompt type ipconfig and press enter key
From the execution find out the default gateway ip address.
This will be your router ip address
4: Now type this address on the internet explorer and press enter key
It will ask fir username and password
Thanks
Apr 20, 2011 | Linksys Wireless-G WRT54G Router
Used malware program to remove av8 but still unable to get internet. Set network manually and able to ping dns
- download / run malwarebytes in safe mode - run/download kaspersky tdss killer - clean/ replace the host file of windows - set your ip to obtain automatically - reset internet explorer - clear %temp% folder - delete all restore points - fixed
Dec 30, 2010 | Computers & Internet
Whats the problem when my phone says communication host not found
The phone is attempted to contact a Project Server and was unable to make the connection because the Host (server) was not found. The Host Name did get converted into an IP Address, but the Host itself could not be located. Often these messages are indicative of a temporary failure, particular if the host / device was functioning properly and no changes were made, at all, and the internet connection otherwise functions properly.
You may need to contact the phone carrier or the manufacturer for second opinion.
Have a great day!
May 14, 2009 | LG Shine CU720 Cellular Phone
Cant find my Router ip to do Port forwarding
click on start and click on run
on run open box type in cmd and hit enter
black window will open, type in ipconfig then click on enter then look for the default gateway address, that;s the ip of your router
dont 4get to rate solution
Apr 09, 2008 | Lucent DSLPipe Bridge/Router
Router
Wijth the router CAT5 cable connected to the host computer, open internet explorer on the host computer, in the address window type http://192.168.1.1 then press the ENTER key. If 192.168..1.1 is the correct IP address of the router you will get the logon screen of the router. BPCS
Dec 28, 2007 | Dynex DX-E401 Router
Unable to access Internet, WAN IP Address present
First you will need to open up your internet browser (Internet Explorer/Netscape) and go to http://192.168.1.1. You will be prompted for a username and password. By default there is no username and the password is admin. Once you arrive at the routers setup page click on the Advanced tab. Once the page finishes loading, you'll find you will be on the "Filters" tab. Look down and make sure that there are no numbers other than 0 in the boxes on that page. If there are, then you will need to replace them with 0's and click Apply, then Continue. Once you've done that, you're going to want to look for Dynamic Routing at the top, and then click on it. Once that page finishes loading, make sure that the "Working Mode" is set to Gateway, not ?Router?, and that tx and rx are set to Disable not RIP-1 or RIP-2. If a static IP address has been set on the computer, verify the gateways matches the Router's LAN IP Address. If there aren't any installed gateways, add the Router's LAN IP Address. When setting static IP Addresses, you must also input the DNS servers. For more information on assigning static IP addresses, please see the related article on assigning static IP addresses. If you?re still having difficulties, please contact Linksys Product Support.
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys WRT55AG Router
Hummingbird HostExplorer Logo
412 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
