Question about NTI Backup Now EZ
Can't run NTI Backup software on Windows 7
Have a new Toshiba laptop and cannot transfer my files on Canvio 3.0 USB HDD
  • Anonymous Mar 16, 2014
    Nti backup won't work with windows 8.1
  • 59 Answers
Try AOMEI Data Backuper. It can work well on Windows 7
http://www.aomeitech.com/features/system-backup.html
Posted on Dec 24, 2012
    Sergeant:
    Champion:
  • 272 Answers
Have you installed the proper USB 3.0 drivers.
If not install the USB 3.0 drivers that support your motherboard.
Posted on Dec 14, 2012
External hard drive transfer rate very slow
Windows 7 has something set wrong if you are showing 2.6GB usable. Windows 7 will recognize 3GB regardless of whether it is 32 bit or 64 bit.
Oct 02, 2014 | Toshiba Canvio Desk HDWC130XK3J1 3 TB...
How do I retrieve my files from Canvio Basics 3.0?
The usual way to back up files is to just open my computer and open the drive that is the external hard disk and just drag and copy the files over. You would then do the same this king to drag the files back to your computer. I am assuming you did not do this and usedsome software that came wwith the drive. In that case I would still open the drive in my computer to see if its there or otherwise u need to use the same software u used to backup the files to recoverthem. If you ccan't figure it out I would redo saving the files the normal way like I explained before . An internal hard drive or even external storage device like USB thumb drive simply shows upas a new drive when plugged in. Do not use an software to save files as usually they are proprietary and use compression which is iinconvenient or makes it difficult to recover
Jul 24, 2014 | Toshiba 1TB CANVIO BASICS EXTERNAL USB 3.0...
Nti backup now error message during installation
Install the software before plugging the device in. You may have to uninstall first. Right - Click on the installation file and click ' Run as Administrator'
Dec 05, 2013 | Computers & Internet
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
My computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Apr 07, 2012 | NTI Backup Now EZ
HOW TO RESTORE FACTORY DEFAULT SETTING MY TOSHIBA SATELLITE L670D WINDOWS 7, KINDLY HELP ME, I TRY USING RECOVERY DISC BUT IT NOT WORK.
If my answer has helped you today please offer four thumbs up as thanks!
Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
Sep 02, 2011 | Toshiba Satellite L670DST2N01 Laptop
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Apr 10, 2017 | NTI Backup Now EZ
I originally downloaded NTI Backup Now EZ software from the Toshiba website to use with an external Toshiba hard drive I purchased and have been running both "File and Folders Backup" and...
Hello bobdurack
I'm not shure this is the solution but it's a possibility : has the letter of your external Toshiba eventually changed ?
Regards ,
fanaudi .
Mar 28, 2011 | NTI Backup Now EZ Software
I'm running Windows 7 on a Dell laptop. It has not completed one backup since I installed Toshiba 500GB portable drive which came with backup software installed on it. While trying to run the backup...
This issue needs to go back to Newtech. They can guide you through the issue. Is the external drive LARGE enough? Windows backup takes huge amounts of room. I suggest Handy Backup Pro, it can pull backup across networks, and push the data to drives and ONLINE locations.
Jan 21, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Jan 08, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
Computers & Internet Logo
436 people viewed this question
Top NTI Computers & Internet Experts
Lawrence Oravetz
k24674
richie46
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
