Question about Microwave Ovens
Turntable stopped revolving
Turntable is properly seated, on/off switch was toggled, but table doesn't revolve
    Scholar:
  • 78 Answers
Could be the turntable motor itself,or maybe your microwave may have an isolator on the control board, if not to get access you need to tip the unit on its side so you can get to the bottom of the unit, (take the plate out first )you will see the access panel in the middle on the base of the uni,t it will have3 or 4 moutings that will need to be cut away then the panel falls off, you will find 1 or 2 screws holding the motor in remove the motor you need to take the part to shop where you will have identify the par,t there so many motors for microwaves speed shaft size and shape they may even test the motor for you,if its not that then best to take to a repair agen,t
Posted on Dec 11, 2012
SOURCE: Light comes on, trun table revolves, does not heat
in all probabaility it is the magnetron that has packed up. had a similar problem,got the part replaced but back to square 1 .
Posted on Jul 22, 2009
  • 945 Answers
SOURCE: Turntable has stopped revolving...
One suggestion i would make is that in the microwave there is the turntable, lift the plate off ,then below it you will see a circular object with wheels on.I think you may have this the wrong way up, so turn it over put the plate back on top and should work.
its the circular piece on runners that is the problem
Posted on Oct 30, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The turntable on my Russell Hobbs SJS21 Microwave
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
I would contact the manufacturer via info in your owner's manual.
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for them.
Posted on Feb 10, 2010
hardrocko
  • 1476 Answers
SOURCE: it won't heat water,but it will turn around
Sounds like you lost your HV diode. Magnetron could be bad but these days they are pretty good. Diode costs about $5 at www.mcmelectronic.com . It is located in left side near the rear and should be straightforward replacement. Let me know how this works out. Thanks for using FixYa. Contact me if you need more info.
hardrocko
Posted on Feb 11, 2010
  • 457 Answers
SOURCE: the revolving glass plate on Panasonic NN-GD546 no longer revolve
the plate is controlled by a rotating motor.the motor is probably stuck or bad.
Posted on Feb 24, 2010
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
Why do I hear a popping noise when turntable revolves counterclockwise.
If the turn table automatically picks up the tone arm and starts the record and changes after the record is over, then you are haering the gear box.
Feb 23, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
Oven seems to be working with the exception of the turntable not revolving
Check that there is no damage to the plastic turntable rotor (i.e the part with wheels) underside the plate. Motor could be working but rotor missing or not connected properly, or damaged. Otherwise the turntable motor or motor driver circuit is fried.
Feb 04, 2015 | Microwave Ovens
Turntable stopped working (yes, I pressed the turntable on/off button)
It all depends on your model number of course, but if JUST the turntable is failing, it may just be a defective turntable motor or coupler.
If your internal cooling fan and/or inside / cavity light is defective, too, it may be the internal fan motor, a door switch, or a relay on the control board.
We repair those and can offer more free advice with the full model number and a little bit more detail about what's working, what's not, and when.
You can find handy exploded views and order parts by model number here.
Nov 27, 2012 | GE JVM1850 1000 Watts Microwave Oven
Unfortunately unless your are under warranty there is not much you can do. The table is driven with plastic gears and these wear or break. You can call a repair shop and if they happen to have the gears from the same model they might be able to fix it cheap enough. Otherwise it might be cheaper to get a new one to get it working again.
If it works other than this you can get a wind up turntable. Not as good as the driven one but these are cheap.
Jan 24, 2011 | Panasonic NN-T583SF Microwave Oven
Electrolux microwave oven model em17 purchased in 2007.turn table not revolving.i am using the oven without revolving table..is that ok?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | Electrolux Microwave Ovens
Turn table will not revolve on panasonic microwave
The turntable motor could be bad or the coupler that the turntable sets on could be worn out. The are the two most common failures.
Jun 19, 2010 | Panasonic Microwave Ovens
the magnetron might be defective, also check the door interlock switches, they cause a variety of problems.
Jun 28, 2009 | LG LRM1250 Microwave Oven
Which microwave has no turntable?
look at the features the new microwaves have. alot of them have a button to turn the turn table off
Jan 31, 2009 | Microwave Ovens
Turntable doesn't spin
Well the table might not be on the revolving piece- that is what happened to my microwave oven, or the revolving piece might have to be connected to a belt inside that turns it
Jan 17, 2009 | Sanyo Microwave Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
