Question about Micro Direct (SYSMDBGAMBASE004) PC Desktop
Warning message at boot up,non-responsive keyborad
Hi.when i switch on my pc the motherboard does not make any beeps and i get the following message- warning!!the previous performance of overclocking is failed and the system is restored to the defaults setting press any key except "DEL" to enter SETUP...   the problem is regardless of what key I press nothing happens.i have tried a usb keyboard and an adapter for it (usb to ps2) but still the keyboard is unresponsive,i have also tried with other keyboards.if you have any thoughts on the matter i would be very grateful.
  • 1 more comment
  • dancingshrew Jan 13, 2009
    yes!!it worked! thanks so much,your a total life saver!
  • Dan rogers
    Dan rogers May 11, 2010
    so the keyboard does not work if you try usb or ps/2?
  • Loteck May 11, 2010
    Have you pressed the "del" key?
    Scholar:
  • 191 Answers
Try this! Open your CPU there you will find CMOS battery remove it and reinsert and there will be a BIOS pin remove it and reconnect. Now Switch On the system.
Posted on Jan 13, 2009
PC will not power up, and power supply is working. The Mother board is in a HP Pavilion a1473W
A few things to check:
Firstly, scheck that there are no blown, or bulging capacitors on the motherboard, this board had a tendency to fail due to these going.
Then, remove all non-essential peripherals and leave only one ram module in the board, try to boot, if it does boot, replace all in turn, booting each time you do so and identify the faulty component.
If it will still not boot, listen for any beeps you may get.. note them down and if there are any, repost your query.
Things to try now:
Remove the cmos battery, leave out for 30 seconds and then replace, try to reboot.
Then try removing all the ram and rebooting with no ram to see if there are any beeps. If it does beep there is the chance that there is still life in the board, if not, the board is probably dead.
Finally, remove the board and power it up on an antistatic surface, using a temporary switch to trip the motherboard pw switch ( or use a screwdriver on the two terminals briefly). If it does power up now, check the switch from the case to the motherboard for breaks or damage, replace / repair and rebuild the tower
Jan 28, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
GA-K8VM800M MOTHERBOARD The problem with the board is that, initially it got the message that disk boot failure, after checking bios settings, still it got same message. I have changed the IDE cables...
Try making your hard drive as the first boot in the bios and just connect your hard drive only on the motherboard ( remove cd/dvd drive, etc..). Make sure your hard drive is detected in the bios. Then restart your computer again.
Oct 11, 2010 | Gigabyte GA-K8VM800M Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
With my mercury mother when I switch on my pc it
Beeps are usually a warning that the computer is having hardware issues, this is usually down to the memory being bad.
Try taking out the system memory and clean the contacts and the slots that the memory snaps into with a clean, dry, soft paintbrush, then reseat the memory and try to boot the machine up.
If it still won't boot count the number of beeps and if they are long or short and post back here.
Regards.
Aug 01, 2009 | Mercury Computers & Internet
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Feb 19, 2009 | ASUS A8S-X Motherboard
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
ASUS Motherboard A7N266-VM
If you have another video card you can try (you can put an AGP card in there, it will disable the onboard video automatically), take that route first. If you can't, or it occurs with another card, it may be your power supply. It would help to know if your pc beeps when you turn it on, and how many - if any - beeps there are.
Feb 18, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Compaq laptop/no boot up
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | HP Compaq Presario V2000 Notebook
Micro Direct (SYSMDBGAMBASE004) PC Desktop Logo
461 people viewed this question
Top Micro Direct Computers & Internet Experts
David Payne
David Payne
Are you a Micro Direct Computer and Internet Expert? Answer questions, earn points and help others
