Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I broke my garbage disposal. While grinding a little too big lemon piece, it just stopped. I checked the fuse box. It was normal. When the switch is on, it makes no sound at all. On its body, It says:
I am not sure if it's Ace Hardware Brand.
  • 1 more comment
  • Harry Goh Dec 11, 2012
    I followed Mr. Len Wast's advice and it worked!!! Thank you very, very much!
    I solved the problem within 5 minutes after I post my question. I also solved my dryer problem recently. Thank you so much, FixYa.com.
    Sorry, Mr. West, not Wast. :-)
  • Ace Hardware Master
  • 5,089 Answers
1) Open following link for complete garbage disposal troubleshoot resources:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Mr West's advice was probably a 'recommended answer' posted some time past, so he might not be able to hear your thanks.
3) Glad fixya works for you.
Others feel same way.
Posted on Dec 12, 2012
lenwest
  • 150 Answers
SOURCE: i have an ace hardware
Get a flashlight get under the sink and look at the bottom of your disposal,there should be a small red button this is the reset,push it in,try it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
Posted on May 16, 2009
  • 5603 Answers
SOURCE: badger 5 garbage disposer does not grind
Some say to put a load of ice cubes in and run it.
Posted on Dec 30, 2009
  • 8404 Answers
SOURCE: My sink garbage disposal just stopped working.
look on the bottom for a little (1/4 round) probably red reset button - press it.
Posted on Jan 18, 2010
Mike258
  • 1498 Answers
SOURCE: My Ace 2000 is very loud, like their is a fork in
Jim,
You are exactly right. Knife, spoon, fork , whatever. that metal on metal sound is produced in the flail chamber.
Get a flashlight and have a look inside.
Needle nose pliers can be handy for extraction.
Mike
Posted on May 30, 2010
My garbage disposal is not working. it "hums", but doesn't grind, and water drains slowly. there is nothing stuck in it.
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
May 16, 2016 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Tip
Garbage Disposal Smells
What can you do if your garbage disposal starts to stink up the kitchen? Because of the stuff that you put down the disposal and grind up the residue can sometimes start to create a foul odor that can be noticed in and around your kitchen. To combat this problem there are some general things that you can do and also some things that you and grind up in the disposal that will help to keep it smelling great.
One of the things that will make the disposal smell bad is if your dishwasher discharges through the garbage disposal. The food left after the water goes through will soon start to spoil and stink. Make sure that you run your disposal after the dishwasher runs to clean out the food and keep the disposal clean.
Some soft foods like meats and cooked vegetables will also tend to stick to the plate of the garbage disposal. These will cause a smell to develop after a time as they breakdown. To stop this from happening keep harder foods or foods that smell better for last to run down the disposal. This will help to clean the plate and keep the garbage disposal smelling better.
If you are going to be away for a long time, or you are having friends over and want your garbage disposal to smell good, you can use a lemon or lemons rinds. Cut up the lemon and grinds it up before you shut down the disposal. This will have your garbage disposal smelling great!!
There are also commercially produced garbage disposal cleaners, deodorizers, and degreasers, that you and buy at most grocery or hardware stores that are made specifically for this purpose.
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
on Feb 06, 2010 | Kitchen Appliances - Others
Frigidaire grind pro 3\4 hp
Replace disposal?
Call about warranty.
Buy another identical one and return defect in new box.
Gene
Nov 30, 2013 | Frigidaire Garbage Disposals
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
My garbage disposal makes grinding noise, as if glass or metal is in it; I've checked and checked and see nothing; what could be causing this problem?
Thanks, Geno_3245. Another thing you may be able to try is this:
(1) find your "garbage disposal wrench" - an offset Allen wrench designed to be inserted int the bottom of the disposal which was supplied with the unit (in a little plastic baggie) when the unit was brand new.
(2) with poweroff, insert the whench into the bottom of the disposal and use it to manually turn the impeller around a few times an see if anything pops loose.
If nothing comes loose, its the bearing screaming before it dies, like Geno_3245 says... so start pricing a new replacement.
May 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The blades on my Sinkmaster 550 garbage disposer needs replacing. How do I take it apart and replace the blades?
that is a project I wouldn't reccomend. besides the "blades" are not really changable. The blades are a piece of metal cut at an angle and when they spin they grind the food by rubbing against a series of holes in the base.
if the disposal is not grinding the food, then its time to replace the disposal.
Aug 07, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Badger 5 garbage disposer does not grind
Dec 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hi. I had a piece of plastic fall down my insinkerator badger 5 and jam the motor. I manage to turn the motor with the allen key to free the piece, but it's still in there making a lot of noise and I'm...
Hi, Use a needle nose plier to get it out or take it down and dump it out...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Dec 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What can a garbage disposal be expected to grind?
all i can think of is that the blades could be dull or the stems were not all out of the disposl and they drained out with normal use. they could be small enough to filter through without being ground.
Nov 15, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
143 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
