Question about Emerson Microwave Ovens
Emersonmicwave sounds like still running after cooking
Soundslike a fan running and cooking
  • Emerson Master
  • 9,047 Answers
In order to give you detailed help, we would need the full model number form the tag on the unit, and the FCC ID number may be helpful, too.
Also, we would need detail symptom info, namely what it does wrong or does not do, and when.
Please include this information in a new post.
Thanks.
Posted on Dec 12, 2012
Fan is barely running. during cook, fan runs weak and vent fan does not run. tech said maybe a control panel? i can do the work but need a parts and service manual. are these available? does the weak...
probably a defective motor or slipping blade. i'm not sure how old your amana is. if it's the real old chrome metal '70's or early '80's vintage models, the part may not be available anymore.. they were very common to fail.
May 16, 2011 | Amana Radarange Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
I have a GE SpacesaverXL model JVM1350BW. It does not heat up. The interior light, surface light, fan, clock, keypad all work normally. When a cooking mode is chosen and START is pressed there is a...
I wouldn't worry about the sensor error right away.
Sometimes that's just caused when the door is opened before steam could be detected or steam was not detected in the maximum amount of time.
Once it's all working again, if you still get the error regularly, it may be a bad humidity sensor.
If the internal cooling fan IS running when you try to cook AND the oven is not heating, it's probably a failed secondary interlock relay on the control circuit board.
If the internal cooling fan is NOT running when you try to cook AND it's not heating, the bottom door switch is probably the culprit.
Here's is a file on checking and replacing door switches.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Listen to that very carefully, and listen to yours to see if the cooling fan is working.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Let me know if I can help you further.
Aug 22, 2010 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
The unit turns on but the it's thermal fuse/breaker shuts it off
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Carousel R-530CW
Hi, I am not sure of the cost concerning the control board, however, it does sound like a control board problem, or a door switch problem, I would need to see the specific unit diagram to know for sure, but many microwaves, not all, but many, have a door switch related to that part of the circuit, usually the fuse would blow at that point, but there again, it depends on the circuit. I would suggest you get the unit checked soon however. Hope that helps somewhat, and thank you.
Jan 24, 2009 | Magic Chef MCB780W Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Cooks fine, but fan & carousel run slow and light is dim
It sounds perfectly normal. A microwave generally draws about 13 amps or more when cooking at full power. That's a considerable amount. This current draw will actually "load down" the power line, resulting in a small but measurable drop in the voltage. The decreased voltage means the light will be dimmer and the motors for the fan and turntable will run a bit slower. BUT if you ever have _chronic_ flickering, dimming or brightening lights in your home, it could be the result of a bad connection on the neutral, etc., which can lead to a very dangerous condition. Once in a while is okay, but if it happens a lot, your landlord or electric company should examine the lines.
Apr 24, 2007 | Sharp R-401CW Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Microwave Ovens Logo
24 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
