GB3BM-024K-AB wiring diagram
Auxilary Heat wiring
4 Suggested Answers
darkbowser
  • 11 Answers
SOURCE: gibson gb3bv-024k-a heat and ac
take it to your local repair man and get it fixed
Posted on Jan 15, 2009
  • 659 Answers
SOURCE: I need a wiring diagram for the fan motor
http://www.nordyne.com/literature/710235a.pdf
This is to your unit. Good luck!
Posted on Apr 09, 2009
  • 6 Answers
SOURCE: i have a problem with
IS IT GETTING 24V CONSTANTLY?
Posted on Dec 02, 2010
Limit switch code flashes no inducer motor or ignition starting
usually the main blower runs non stop when limit circuit opens. Shut off the power and check each limit with the wires removed. Use your meter, check the same way as you would check a fuse. Sometimes you can tap on the main limit to reset it. Some secondary limits have a small plastic reset button in between the wires. Check this also.
Nov 27, 2011 | Goodman Heating & Cooling
I purchased a Hunter Universal thermostat with 5 minute installation instructions. The man at the local Lowes said that a child could change them out. I followed the directions but ran in to a problem. I...
The W2 terminal is second stage of heat. E is for emergency heat.
If you have a heat pump, normally these two will be tied together. They may be together at unit.
If you have a heat pump, and just one other auxilary heat these will be together. If you have 3 stages of heat, i.e. heatpump plus resistant plus another, you may need a different stat.
Feb 04, 2011 | Heating & Cooling
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Jan 10, 2011 | YouTube Videos
Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Mar 04, 2010 | Heating & Cooling
Sometimes the auxilary heat light comes on, and this morning the auxilary and emergency lights were on. Our electric bill has been really high the past two months.
Assuming we are talking about a Heat Pump system with an outdoor condensing unit and an indoor air handler, it is not uncommon for electric bills to escalate during the harder winter months.
Typically, the auxilary heat light energizes whenever the electric strip heaters are in use. These heaters are used to supplement the heat from your heat pump system which will be unable to maintain desired occupied setpoint with outdoor temperatures below 35degF. At outdoor temperatures below 35degF is not uncommon for the heat pump to run non-stop and the electric heaters will cycle on and off as the temp in the house drops between 1/2 to 1 1/2degF below setpoint. The electric heaters will also come on when the system goes into a defrost mode...defrost modes typically last anywhere between 2 - 8 minutes. The emergency lights, depending on your thermostat, will come on whenever the thermostat is placed in EMER HT. Some systems energize the emergency heat lights to indicate there is a problem with your condensor unit.
I suggest you ensure the thermostat is in HEAT mode and not EMER HT mode. Also, while the system is running, step outside and visually inspect your condensing unit. Is it running? Does it appear and sound like it is running normally?
Don't forget your air filter. This is the single most important and most-neglected maintenance item on your system.
If after these steps, you still feel as though you are having problems and would like to try and correct them yourself, please let us know.
I hope you find this information helpful. Good Luck to you! :-)
Feb 26, 2010 | Weather King Heating & Cooling
I need to wire a taxi roof sign to my car fuse box in my 2003 vw passat
go under the strering wheel and test ur auxilary with a power tester the one that turns on and off when u turn on and off ur key is the auxilary just tap the power wire there and the ground to metal and then everytime u turn ur car on the light will turn on and when u turn ur car off it turn off and when u have the key half open ur light will be on just like ur car stereo
Jun 25, 2009 | Car Audio & Video
I am replacing a white rodgers thermostat with a honeywell rth3100c. i have matched my wire as e (brown) to e w2 (white) o aux y (yellow) to y g (green) to g o (orange) to o l blank r (red) t r b blank c...
Blue (C) or sometimes (B) should be your common wire. Look at your schematics and locate common. Your Brown wire is (E) and is emergency heat, white wire (W) is Auxilary Heat, green wire (G) is fan relay, red wire (R) is power, yellow wire (Y) is Cooling and orange wire (O) is reversing valve.
Dec 02, 2008 | Heating & Cooling
I have a coleman evcon t-stat that is using 7 wires. I want to switch to a honeywell th3110d non-programmable t-stat but don't know where the wires should go.
The most common wiring is: This sometimes varies as to installers preferance.
Red wire is your supply power to the T-stat. R terminal
Green wire is the blower fan. G terminal
Yellow wire is compressor contactor Y terminal
older units used a blue wire to Y
White wire is heat auxilary or black wire W terminal
Orange wire is reversing valve O terminal
Blue wire is the common C terminal
Black wire can be emergency heat E terminal
Best thing to do is replace wire for wire from t-stat to t-stat
or write down the colors to which terminal on the old t-stat and match to the new. make sure you SECURE POWER to the Air Handler, furnace and condenser before replacing any t-stat.
It is very easy to short the wires out if the power is left on and take out your A/H low voltage fuse or transformer.
May 18, 2008 | Heating & Cooling
Heating & Cooling Logo
524 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
