Question about Sansui HDPDP4200 42 in. HD-Ready Plasma Television
I have a 42" Plasma Sansui and just recently there are now multiple lines running through the screen. This makes it impossible to watch. I've tried the power, cords, stations, etc. Any ideas of pr
Multiple horizontal lines all through the screen, some colored and some black. TV is almost 10yrs old. Son was playing X-box when this happened.
    Top Expert:
  • Sansui Master
  • 14,553 Answers
Ten years is two lifetimes for a Plasma, it most likely is either the display panel itself or a main board, in either case not cost effective to repair or smart but the real problem would be parts, I bet almost zero is available for this.
Posted on Dec 11, 2012
SOURCE: Top half of screen blacks out
Today, after speaking to the Sansui Manufacturer representative from Japan. He stated that all you need to do is to turn off the closed caption from the TV remote and not the DVR remote. Black screen can occur at the top half or the bottom half of the screen depending on how it was originally setup during installation. Try this and hopefully this fixes the problem.
Posted on Nov 26, 2007
CodeWarrior
  • 13 Answers
SOURCE: my "42" inch sansui plasma monitor
You don't have any magnet anywhere near the TV do you ?
If not it sounds like something magnetic is interferring with the picture.
If not get the warranty out :D
Posted on Jan 27, 2008
  • 208 Answers
SOURCE: Coloured Pixels in or around black areas when watching TV
This is know as a diffusion issue. Most times this can be corrected with some minor alignment on the pots on the YSUS pwb. Sometimes the YSUS pwb has failed and will need to be replaced.
Posted on Feb 04, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Sansui 42" Plasma
First we have find out if it's the set or the signal, So does this tv have snow on all inputs or just on cable? if just the cable try a another tv in its spot, if the problem continue mabe a call to the cable company is in order, I know that many cable problems come from bad conections or loosing a grounding point were the cable enters the house, Now if the problem shows up when watching a DVD or other video source it may be the tv's fault. Most likley a voltage is droping and need to be repaired perty quickly. What some people see as snow we see as a low VA voltage that is putting stress on a control board
Posted on Feb 13, 2008
rulds2008
  • 3866 Answers
SOURCE: black band
I found replaing the inveter worked on most of these Tv's that have the band, and or stipres going acrros the Tv. You can also check out this website www.teexp.com and see if they come out to you're area to have it looked at.
Posted on Jul 01, 2009
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
Lg 42lg70yd aa Weird screen problem
I've tried the link, but failed to see your youtube video. Anyway, if there are vertical lines, and all of them are closed to each other, indicates either a T'Con or Panel problem. To make it sure, just get into this link http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar or see it in Timeslide option. There are screen shots of different problems to flat panel TVs. Compare them to your TVs' and make sure about the fault.
Jun 17, 2013 | Televison & Video
I have a 42 inch plasma sansui for 3 yrs now and just recently a black line appear in the middle of the tv almost like separating the picture in 2. what could be the cause of this can it be fixed or has it...
I dont believe it could be anything to do with the remote. It sounds to me like some thing is wrong with the line producer. If i was you i would take it to my local TV repair man. It maybe some thing simple.
I hope this helps.
Apr 08, 2011 | Sansui Televison & Video
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sky PDS4250 42'' Plasma TV - Black line down centre of screen
not sure if this is the fix or not ...but i was tryin to fix a problem with my tv(not the same as yours)...but in the menu under adanced you can split the screen ....when i do that it puts a blue line down the middle of the screen
Dec 04, 2008 | Protron PLTV-4250 42 in. LCD Television
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Oct 06, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Sansui HDPDP4200 42 in. HD-Ready Plasma Television Logo
123 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
