Question about Worldwide 2001 Volkswagen Jetta GLS 2.0L Alternator - 90 Amps
P1128 Throttle control motor lock malfuntion - Worldwide 2001 Volkswagen Jetta GLS 2.0L Alternator - 90 Amps
How do you fix toyota fault code p1128? The car is a toyota progre? nc250
Throttle Control Motor Lock Malfunction, is the error. Look around for a loose wire.
Apr 23, 2018 | Toyota Cars & Trucks
Malfuntion code c-5102 for oce imagistics cm2520
C 5102 - Main motor malfunction.Check the I/U unit gears,Fuser unit gears it is a mechanical locked problem.
Feb 01, 2013 | Konica Minolta bizhub C250 All-In-One...
P1128 Throttle Control Motor Lock
Hi there:
The P1128 means that the drive by wire throttle body has been stuck or is locked up. With the key off you should be able to remove the intake boot and take your fingers and push the throttle plate open, if you cannot this means the throttle plate or motor is stuck with either carbon or the mechanism has locked itself. Remove the battery cable or clear the codes with the code reader and see if they will clear before you attempt to start the car.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 07, 2012 | 2002 Toyota 4Runner
Engine management light on-P1128 Manufacturing control
No such code listed (P1128) for 2002 Accent
Aug 29, 2011 | 2002 Hyundai Accent
I get codes P0102 and P1128. My mechanic says I need to put a new mass air flow sensor on and it will take care of the problem. Is this correct?
This could very well be correct I believe code P0102 is the mass airflow circuit low input. P1128 should be a lean code.
I would first try cleaning your mass airflow sensor with a carb or throttle body cleaner, they have a tendency to get dirty and not read correctly.
Dec 13, 2010 | 2001 Volkswagen Cabrio
The code is saying that its the idel control malfuntion what is that
IAC VALVE ( IDLE AIR CONTROL) CONTROLS RPM AT IDLE. LOCATED ON THE THROTTLE BODY.
Feb 02, 2010 | Dodge Durango Cars & Trucks
Trouble codes P0172 and P1128 - VW Beetle
The code P0172 means...system too rich(cyclinder bank No.1)..and all of the OBDII fault codes begin with a "P0"..i dont know what a P1128 is....i hope this will help you
Jun 28, 2009 | 2000 Volkswagen Beetle
P1128 code
I looked on alldata, and my Chrysler site, and there is no P1128 code listed. Are you sure the code is correct? What motor is in it? I looked for the code online for generic reasons, and it says it is for upstream heated O2 sensors swapped. Never heard of this code ever in 14 years of service work.
May 28, 2009 | 2006 Chrysler Sebring
I have problem with code 1126 (toyota 4 runner 2001
Manufacturer Specific Codes
P1100
BARO Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1120 Accelerator Pedal Position Sensor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit - Read Our Article on Automotive Circuit Testing For Help With This Toyota Check Engine Light Code
P1126 Magnetic Clutch Circuit
P1127 ETCS Actuator Power Source Circuit
P1129 Electric Throttle Control System
P1130 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1133 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1135 Air/Fuel Sensor Heater Circuit Response (Bank 1 Sensor 1) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code - More Related Information
P1150 Air/Fuel Sensor Circuit Range/Performance (Bank 1 Sensor 2)
P1153 Air/Fuel Sensor Circuit Response (Bank 1 Sensor 2) - Read Our Article On Oxygen Sensor Codes For Help With This Toyota Check Engine Light Code
P1155 Air/Fuel Sensor Heater Circuit. (Bank 1 Sensor 2)
P1200 Fuel Pump Relay Circuit
P1300 Igniter Circuit Malfunction - No. 1
P1305 Igniter Circuit Malfunction - No. 2
P1335 No Crankshaft Position Sensor Signal - Engine Running
P1349 VVT System
P1400 Sub-Throttle Position Sensor
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1411 EGR Valve Position Sensor Circuit Range/Performance - Read Our Article on EGR Valve Codes For Help With This Toyota Check Engine Light Code
P1500 Starter Signal Circuit
P1510 Boost Pressure Control Circuit
P1511 Boost Pressure Low
P1512 Boost Pressure High
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit
P1600 ECM BATT Malfunction
P1605 Knock Control CPU
P1630 Traction Control System
P1633 ECM
P1652 Idle Air Control Valve Control Circuit
P1656 OCV Circuit
P1658 Wastegate Valve Control Circuit
P1661 EGR Circuit
P1662 EGR Bypass Valve Control Circuit
P1700 Vehicle Speed Sensor '2' Circuit Fault
P1705 Direct Clutch Speed Circuit Fault
P1765 Linear Shift Solenoid Circuit Fault
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
Back To Top Of Toyota Check Engine Light Codes Page
Mar 21, 2009 | 2002 Toyota 4Runner
P1128 code on 2000 hyuandai accent
I did some research because the P1128 is an odd code for Hyundai and I couldnt find a lot of information on it, but I found two things that may help and neither point to the fuel pump.
1. P1128 in Hyundai refers to the Mass Airflow Sensor or MAF being defective.
2. There is a TSB from Hyundai, TSB 01-36-022, but I wasnt able to ascertain if that was a specific TSB for the MAF or if it was information on how to test the MAF or some other information.
P1124 seems to be a related code as well but I could find little on it. P1124 in a Subaru is an issue with the Throttle Position Sensor or TPS, but I could not confirm that for Hyundai.
My first suggestion would be to check your air filter and if it has not been changed in a while or is really dirty, then change it as a restriction in air flow might be mistaken by the computer as a problem with the MAF.
Jan 02, 2009 | 2000 Hyundai Accent
Worldwide 2001 Volkswagen Jetta GLS 2.0L Alternator - 90 Amps Logo
22 people viewed this question
Top Worldwide Electrical Supplies Experts
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
