Ricoh aficio mp c6000 light copy - Office Equipment & Supplies
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 990 Answers
SOURCE: Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Posted on Jan 27, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Posted on Jan 28, 2010
  • 161 Answers
SOURCE: When i copy o print a document, it comes out with
a) If possible remove the drum unit and see if there is a paper stuck in the drum unit.
To remove the drum unit first open the front and right door. Then remove the toner holder(green lock).
Then pull the drum unit out from the front of the machine(press the lock).
b) How many prints(copies) has the drum made ?
The life is 60000.If it has crossed its life replace it along with the developer.
Posted on Mar 16, 2010
  • 114 Answers
SOURCE: scanrouter v2 lite at ricoh aficio MP 4000
you dont need scanrouter for mp 4000
Posted on Mar 21, 2010
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Hello ,, I have Ricoh c 6000 and I have problems with functional with copier ,, can help anybody
the purpose of this site is to help you. So, post the image/error and we can help you, so everyone with that problem can see the solution
Nov 20, 2014 | Ricoh Aficio MP-C6000
Ricoh mpc 6000 hdd change
hello when i replace two new hard drive in the machine sais can,t not format the hard drive can somebody help me to fix the problem
Jun 04, 2014 | Ricoh Aficio MP-C6000
Ricoh aficio mp c4500 factory reset
Selam Ashraf, user manual should be available on ricoh.com. I use it too asI have a ricoh lazer printer. It is easy to use
Huseyin
Feb 03, 2014 | Ricoh Aficio MP-C6000
How do I wipe the hard drive on a Richo Aficio MP C6000 MFD
Depending on the OS you are using, just format the drive. You could get a copy of Norton Utilities and do a multi-pass secure wipe, but usually just a straight format from the OS will do the trick.
Jan 02, 2014 | Ricoh Aficio MP-C6000
Ricoh aficio mp c6000 factory reset
1. Press the * key and the # XXXXX on the Ricoh copier at the same time and hold for 10 seconds.
2 After 10 seconds or so, the printer will restart itself and will be factory reset.
Dec 09, 2013 | Ricoh Aficio MP-C6000
Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
Jul 02, 2012 | Ricoh Aficio MP-C6000
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
k24674
