Question about Intel D845HV (735858149143) Motherboard
I need help
I just install d845hv motherboard it try to start up but it stop the moniter dose not turn on.i know the moniter is good can any one help
    President:
  • Intel Master
  • 1,314 Answers
Make sure the video card is good and also that it is seated in the slot properly. You may need to actually remove it from the slot and push it all the way back in to reseat the card to make sure it is in all the way.
Posted on Jun 11, 2007
  • Kevin Shafer
    Kevin Shafer Jun 12, 2007
    You marked it irrelevant; how about some more information then? If the monitor is good and it is not getting video, it is the video card. Either the video card is not installed correctly or the video card is bad (or onboard video).
I have a PI865D7 mercury motherboard when i start the pc, computer turn on fan is running all light on but no display in moniter i check the ram, it is ok so please could you help
you may re-seat your ram, video card and processor and pci cards. Turn it back on and see if that works. If you have to do that often then your motherboard has a bad connector or socket on it. If you just installed somthing on your pci slots take them out. If re-seating your ram video card processor and pci slots doesn't work, remove all pci cards and try, If that method works, install them 1 at a time and see when it stops working to isolate the problem.
Good luck hope your motherboard isn't shot,
Christopher
May 27, 2012 | Mercury Computers & Internet
I have an Intel D845HV motherboard running with a
In short, yes you can upgrade to a P4 cpu but from the compatibility chart at Intel support, it looks like the upper limit for this older board is the P4 2.6GHz.
Note: Even at that, running the P4 2.6 would require a BIOS upgrade to P12 or greater.
Luckily, the following link has the information you seek: (for BIOS info, click the "BIOS Version" link in the upper right corner of the compatibility table provided)
Intel D845HV CPU Compatibility
I hope this info is helpful!
Mar 08, 2010 | Intel D845HV (735858149143) Motherboard
My screen to my laptop dose not work what do i do
if its totaly blank , the first thing you should try is connecting it too an external moniter, that will rule out motherboard or graphics card problem if you get a display to an external moniter
Mar 02, 2009 | Toshiba Satellite M35X-S311 Notebook
Problem Regarding Booting
due to the increase in temperature inside the cpu for the protection of the motherboard and components it might not be getting started ..
this happens if the processor fan is not running properly or if it stucked due to some dust or obstacles ...
try cleaning it after separating heat sink and processor ....
after refitting the processor trying booting it should work ....
if needed replace the processor fan ..
regards
-Dileep
Nov 27, 2008 | Intel D845HV (735858149143) Motherboard
Processor Upgrade and Memory query
This motherboard supports up to 3gig of RAM so you can go ahead and upgrade it, There's no particular order fo install the RAm just put it to the empty slot then that's ok..
Hope that helps.........
Aug 21, 2008 | Intel D845HV (735858149143) Motherboard
Motherboard changes
Since that board is a Socket 478, there aren't too many choices for you. The below link has something that would fit your needs.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138079
Chris
May 28, 2008 | Intel D845HV (735858149143) Motherboard
Can't connect front panel Power SW cable
On your board in the corner at bottom, you find pins for front panel Power Switch Cable, over there in small characters PWR SW is written, you can put your Power SW Wire there
Jan 02, 2008 | Intel D845HV (735858149143) Motherboard
Front Panel Connection Problem
if you look at the PDF file here:
ftp://download.intel.com/support/motherboards/desktop/d845hv/A6513601.pdf
On page 68 you can see it more clearly. Just enlarge the file.
do you know the make and model of the case?
Nov 20, 2007 | Intel D845HV (735858149143) Motherboard
I really need help
There seems to be two issues here, the front switch on/off button, should turn off if you arent getting any video to the monitor, unlike when booted into windows when you have to press and hold the button in. there could be a number of reasons for the monitor not coming on, but if you cannot get into the bios (f2 or Del on boot up) the cmos chip is corrupt or faulty and require that you clear the cmos by the CLRCMOS, JBAT1 terminal, refer to your manual for the exact terminals and try re booting the pc. if you can get into the bios, go to advanced cmos settings and ensure that agp is set as primary graphics adapter if you have a graphics card, or pci, if not vga should be set as the primary controller. Also check that the motherboard is not touching/shorting on the pc casing, and that the memory that you are using is compatable with the motherboard normally signaled by one beep, proceeded by another for the graphics.
Jun 11, 2007 | Intel D845HV (735858149143) Motherboard
Intel D845HV (735858149143) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
