Question about Dryers
Why cant i find any thing about fluoresent HOUSE lights on here
Cant get the bulb out to change it
    New Friend:
It could be because you posted this under electric fans instead of lighting. You need to twist the fluorescent tube 1/4 the way round to release it from the tombstone ends. If the fitting is old this can be hard to do and the tombstone ends can become brittle and break.
Posted on Dec 12, 2012
Why will the lights no longer come on, on my ceiling fan, when the fan works fine & everything else is fine? What happened?
you get a slight shock suggests that you have a major wiring problem
at some point the installing electrician has used a ground wire as a neutral wire and there is live feed back that should not be occurring
Get in an accredited professional electrical inspector to run a full scan and test on the house wiring and then go from there
Jan 01, 2018 | Home
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
How to change bulb thats a t8 fluresent fixture in a home
A Lot of the T8 style have very little room to move the tubes around, check a few things:
See if you need to remove the tubes in a specific order,
See if the ends of the fixture are removable,
Instead of dropping both ends of the tube drop one side first,
Sometimes after the tube has been twisted and dropped slightly you may have to maneuver the pins to avoid the fixture.
Dec 11, 2012 | Philips 6996C FKD 230V 1000W Lighting
The 911 flashing light on our lamp post does not work?
wow that seam's like a good one, you may need a 3 way bulb in the lamp post? thats the only thing i can think of without looking at it.
Apr 08, 2009 | Electrical Supplies
How do I change the headlight on 00 toyota echo?
You gotta twist the whole thing, before you take off the wires from the back of the bulb about 45 degrees, then pull straight out. It's not "screwed in" like a light bulb in your house. I just changed mine, and had to figure it out. Took me a minute, but I got it. It's a small space in there. Good luck!
Mar 13, 2009 | 2000 Toyota ECHO
No pictrue
Is the LED light purple ?
I have only read bad things about this model. Here are some of the things I have come across. Try this first. With the TV on, unplug it, wait a few seconds an plug it back in. You may also turn off the energy saving mode.
Beyond that the problem could be one of four problems;
1) Bad cable connection to inverter board. Make sure all cables are firmly seated.
2) Inverter board is bad.
3) Power to inverter board is bad.
4) CCFT(cold cathode fluoresent light) has problems.
Mar 08, 2009 | Westinghouse SK-32H240S Television
Fall in water
Keep in Heat For Nearly a Day.
OR Hold it Below a High POwered Bulb Fluoresent.
Jan 09, 2009 | Sony Ericsson K750i Cellular Phone
DLP TV Samsung HLP4663W
Your problem could be your lamp is not seeted all the way in. Take you lamp out and put it back in. Or it could be you ballast that lights you lamp is bad. You may need a new ballast.
Mar 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Frig
just like replacing a house light bulb. if it has a plastic cover, remove first the plastic cover and unscrew the old bulb and replaced it with a new one. unplugged it first before doing the bulb replacement. for safety...
Feb 02, 2008 | Refrigerators
Dryers Logo
Top Dryers Experts
