Question about HP Computers & Internet
Windows vista laptop failing to connect to some wifi networks including my home one.
The signal strength is excellent but the access is local only. Possible to connect to other wifi networks and other devices are connected to the home network just fine.
  • HP Master
  • 7,627 Answers
Open Network and Sharing Center, Manage Wireless Networks, Remove your Home one. Exit Network and Sharing Center. reboot machine, Try to reconnect to your home one. If that fails, Release and renew IP : http://www.cs.cmu.edu/~help/networking/IP_renew.html
Posted on Dec 12, 2012
  • 8 more comments
  • Louis Antwi Dec 14, 2012
    Thanks for the suggestion but no luck unfortunately. Still reading as an Unidentified Network with Local Only access but Excellent signal strength.
  • max carson
    max carson Dec 14, 2012
    Is your Wireless device Secured with a security password? A SSID?
  • max carson
    In the Tray Notification Area ,right click Network and Sharing Center, open Manage Network connections, Disable your Wireless Network connection , enable your Wireless Network connection. No luck, Open Control Panel, Device Manager, Open Network Adapters, right click on your Wireless Adapter, Uninstall and reboot machine. This will force Win Vista to reinstall the correct driver..
  • Louis Antwi Dec 16, 2012
    No luck I'm afraid. I don't think it is the Network adapter as the laptop can connect to some other wifi networks just fine. Yeah, you have to put a password in to connect to the network.
  • max carson
    max carson Dec 17, 2012
    Have you reset the Home Wireless Device to Factory Defaults? And start from the beginning .
  • Louis Antwi Dec 18, 2012
    How do I do that? Thanks for all the suggestions by the way.
  • max carson
    max carson Dec 18, 2012
    I don't know what the wireless device is , Make ,Model? FIRST, Connect a Ethernet cable from the laptop directly to the wireless device. Does it Connect? Can you Get on the Internet? YES or NO?
  • max carson
    Also Open Control Panel, Internet Options, click on Connections tab, click on Lan settings, If Automatically Detect settings is not CHECK , Check it. Reboot. Let me know , Yes or No.
  • Louis Antwi Dec 19, 2012
    Yup, I connect to the internet through the ethernet cable usually. It's a HP Pavillion dv6700 running Windows Vista. The LAN is set to Automatically Detect.
  • max carson
    max carson Dec 19, 2012
    Again, I don't know your OS or the computer make, model? Open Device Manager, Network Adapters, Uninstall the Wireless Network Adapter, reboot computer, the OS should ID the Wireless Adapter and apply the driver.
YourTech
  • 63 Answers
SOURCE: ethernet controller friver
There is no availabe network driver for this Latitude d600 found on the dell support website that will work for vista. Most probably this computer is not configured to work with vista.
Call Dell Technical support for answers.
Posted on Aug 26, 2008
Geekman
  • 32281 Answers
SOURCE: Lenovo 3000 N500 - unable to connect to Wireless Internet
You need to get the wireless authentication details from the library's front desk to configure your wireless connection. They should be able to help you.
Posted on Feb 19, 2009
SOURCE: Laptop can't aquire IP address
I had the same problem, went to Microsoft and found this solution on line.
1. Click Start, click Run, type %SystemRoot%\system32\services.msc /s then click ok.
2. Double-click Wireless Zero Configuration.
3. In the Startup type list, click Automatic (if it shows Automatic already, change it, then put it back to Automatic, that will activate the Apply button) then click apply.
4. In the service status area, click Start, and then click OK.
That fixed it for me after fighting it for about a month.
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: I can't connect to the internet on my ACER Aspire
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable
Posted on Mar 25, 2010
elix0411
  • 3530 Answers
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
Posted on Apr 13, 2010
Tip
Troubleshooting Laptop WiFi Connectivity Issues
Most laptop manufacturers provide an external switch to switch on/off the WiFi functionality. As a result, the first problem most new laptop owners encounter with trying to connect to a wireless network is that their WiFi has inadvertently been switched off. So, if you have a WiFi connectivity issue, the first thing to make sure of is that your laptop's WiFi external switch is on.
The next most common problem when it comes to WiFi connectivity issues is that the signal strength is too weak to hold a connection. This can be extremely confusing if the network is working fine for a person sitting at the next table. This could be due to several reasons. This person's laptop might have a more sensitive WiFi receiver, be set in just the right location where the signal strength is maximum, or even be accessing a different WiFi network other than the one you are trying to connect to. When you're troubleshooting a wireless connection, make sure to get as close to the router as you can, certainly in the same room if it's in your own home, so you can eliminate signal strength as a possible issue.
In order to prevent every stranger who walks by from accessing any network with WiFi capability, there are a number of security options that can be set on WiFi routers. The most common of these is simply enabling password protection, so that any laptop trying to connect to the network will have to provide a password for the initial connection (after that the operating system remembers the password). In order that you be able to connect to a WiFi network, you will have to set up your laptop's WiFi connection with the correct key. First, try the key printed on the router label, but if a custom password was created when the network was set up, you'll either have to find the piece of paper where it was written or chase the person who set up the network. If the password absolutely can't be recovered, search the Internet for how to reset the router (varies with brand), create a new password and enter it on all the computers that use the connection.
In some cases, it's easy to reset the password or turn the security on and off by connecting directly to the router with an Ethernet cable and typing the fixed IP address for the router into your browser.
Connecting directly by cable to the router is an important troubleshooting step for wireless connectivity even if you don't have a password problem. If you can't connect to the Internet even after plugging directly into the router, neither the wireless adapter in your laptop nor the wireless transceiver in the router are at fault.
If you plug directly into the router via the Ethernet cable and you gain access to the Internet, you can continue troubleshooting wireless issues. Check Device Manager to see if it's complaining about the network hardware. If not, and you still can't gain access at this point, the problem is either with the high speed modem and ISP, or a networking software issue within the operating system.
High speed modems, often called routers if they include a built-in router, are equipped with a series of status LEDs that can be used to diagnose many connectivity problems. Whether you have a cable modem connecting to the cable company, DSL via the phone company or one of the more esoteric high speed modems, they should always include an LED that tells you if the connection between the modem and the Internet has been established. If this link light is out, or has changed colors, say from the familiar green to an ominous red, power down the modem and turn it back on again. This hard reset will usually fix dropped connection problems caused by storms, power surges or signal interruptions, providing the modem hasn't been damaged. A modem/router will also include a status LED to show whether an Ethernet cable connection to your laptop is good, and your laptop will have a little status/activity LED for the network connection as well. While color coding isn't universal, solid green usually indicates a good connection, and blinking green or orange usually indicates activity. Some modems include an LED to tell you if the DSL or cable link to the ISP is good even when the Internet isn't functioning.
Operating system issues affecting connectivity can include firewall (security software) settings that prevent your computer from establishing communications with the Internet Service Provider (ISP), or the failure to install the software that ISP requires. Unfortunately, there are also more complicated problems that will require drawn out conversations with the ISP's technical support department to troubleshoot.
If you're adventurous, or desperate, you'll find all sorts of third party software online that will reset the Windows stack or change registry settings back to defaults, but you're better off trying the tech support route first if a software glitch is at the bottom of your problems.
Please Vote for this Tip if you found it helpful.
M. Omran
on Oct 25, 2010 | Computers & Internet
Can't find the wifi signal
Assuming that you are using Windows, the D-Link is properly installed, and that you can go to Start; Settings; Network Connections: and your D-Link appears as a wireless network and that when you double click on it you see a box that lists "wireless networks" that indicates either " no wireless networks in range, or there are some networks, but they are all encrypted, then you are not in range of a wifi hotspot or free wifi access point. If you live in a mobile home as I do you will find that the metal walls effectively block the signals.A simple device that you can use to increase your signal strength can be found if you google "Surf rider" when you are on the net. Find a friend with a laptop, go to a Mcdonalds or a Starbucks hotspot and test your D-Link to verify that it is working Dan
Apr 23, 2012 | D-Link AirPlus Xtreme G DWL-2100AP...
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
Unbranded 7" wireless book can
I have the same problem. The only way I could get it to work is to click on the wifi icon. Select the wireless information tab, select your connection. Right click on it and delete it. Then Add new and reinstall. Right now I have to do this every time I power down or 'Suspend' but it does work.
Jun 02, 2011 | Computers & Internet
I have connected to wireless network and it says excellent signal strength but windows explorer will not open up any sites. Cannot find server or Dns error. HELP PLEASE!
Dear Suzy,
You have to setup WiFi for your laptop.Some time wireless connection is encrypted with password. To get connect internet you have to unclock encrypted password.Before going to that set your wifi adapter ip configuration default or automatic.
I think it helps.Let me know
Dec 28, 2010 | PC Mall RAZORBOOK 400 Notebook
I can't get internet connection even though it says my connection strength is "excellent."
The netbook is working fine. The WiFi connection or SPID may require you to login as in it is a protected signal. The "Excellent" means that you are receiving an excellent signal from the router. What you want is internet access which is upstream of that. Try a different SPID or connection.
Nov 25, 2010 | Sylvania G-Netbook
I have a Sitecom WL330 wireless repeater
Hi I'm having the exact same problem with a Sitecom WL330 and a BT business hub. Just get unidentified network when trying to connect. Did you resolve your problem? and if so how?
Thanks
Jan 16, 2010 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
Aug 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
323 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
