Question about Hoover HDC7FM Dryer
Belt change on TL22
I have changed the belt on the Hoover TL22 tumble dryer, but now it seems the belt is too tight. The tensioners or self tensioning so how do i loosen this belt
  • 30 Answers
You might want to check to make sure that you bought the correct replacement belt. A new belt SHOULD fit correctly if the replacement belt is the right one? Did you buy an original belt or a generic one? I have ran into problems by trying to substitute for the original. If I were you, I'd double check the belt #. It sounds to me like the belt might actually be the wrong one & be a little shorter than the original. Let me know if that works for you? It should. Good luck and have a good day!
Posted on Jan 13, 2009
Whirlpool Clothes Dryer AWZ 121
It sounds like it is the belt. When the dryer heats up the belt expands a little and when it gets wore out, the tensioner doesn't have enough spring to keep it tight. It might work a little when it's cold before the belt expands.
This belt should work for your dryer but verify the length.
Here is a helpful Youtube video on how to do the repair.
Here is a link to the Service Manual
The bottom of this link shows some typical ways a belt runs past a tension wheel and links for your dryer. If you replace yours I would recommend taking a couple pictures before removing the old one so you can refer to them when installing the new one.
Mar 17, 2014 | Dishwashers
I am trying to change the belt on my electra tumble dryer but cant get it onto the spindle as there is a spring loaded pulley wheel also?!!!1
put the belt onto the tension pulley first then use the large diameter drum to assist you in in LEVERING the belt on with tensioner spring in place . Failing that remove and replace spring with vice grips (put spring back on as it came off ).
Aug 13, 2011 | Dryers
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Jul 07, 2008 | Zanussi TC7114W Electric Dryer
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Apr 06, 2008 | Dryers
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Sep 23, 2007 | Dryers
Belt tension
there is a spring-loaded belt tensioner pulley. make sure it is part of the belt loop. you will need to move the tensioner pulley against the spring force then place belt on tensioner pulley and then release the tensioner pulley and belt will now be tight.
Sep 12, 2007 | GE DLSR483EE Electric Dryer
Hoover HDC7FM Dryer Logo
252 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
