Question about LG VX8300 Cellular Phone
Phone stays in car kit mode - LG VX8300 Cellular Phone
  • altemimis Feb 01, 2009
    where do i take it to get fixed
  • 75 Answers
Sounds like your phone needs to be replaced. When a phone wont come off of car kit, it means that there is something wrong with it. My friend had this same phone, and verizon told her to replace it. Its an older model phone, so I'm guessing you have had it for some time. There is a chance that you could have it fixed, but it would probably cost you more to do that than to just get a new one. Good luck.
Posted on Jan 13, 2009
Need to pair jabra Bluetooth car kit with mobile phone
You need to put the Car Kit in pairing mode, usually done by starting with the power off and holding the power button till the light flashed Red and Blue or solid Blue.
Then search for the car kit from your phone. Once found pair using pin code (pass key) 0000 or 1111 or 1234.
May 04, 2010 | Jabra Bluetooth Car Kit with Night Driving...
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Also this can happen due to shortening of the 2 power pins at the bottom. Try using an alluminium piece cone shaped and toggle the pins. They will come out. Car Kit mode comes sometimes due to moisture in the power pins, shortening it.
Sep 18, 2009 | LG VX3400 Cellular Phone
My phone is in car kit mode i cant use my phone how do i take it off?
You have not mentioned the make and model of your phone. In the settings there must be some place where you had specified the car kit. Put it back in the normal mode in the settings. It must be in connectivity thru USB or some such place. Try to find the car kit option and change it.
Aug 06, 2009 | Cell Phones
Same problem as this person.
Hello
Im sorry to hear about your problem.
If this problem happened directly after getting water on your phone then it could have been a result of shorting out and putting the phone in car kit mode (the mode for when you are using it along with a car kit) . If this is the case then your phone can't be fixed.
If the problem did not appear after the water damage then you may want to refer to the manual to find instructions on switching the phone off of cat kit mode.
Post back if you have any further questions. Thank you for choosing Fixya!
Jun 23, 2009 | LG VX8300 Cellular Phone
Get rid of car kit mode on LG VX6100 cellular phone
try putting a toothpick in the earpiece socket. It worked for me in seconds.
May 19, 2009 | LG VX6100 Cell Phone
Car kit mode
ok take a paper clip, and lightly graze it inside the chargerport of ur phone, slowlymove it left and right, lightly rub it against the top half of the little piece inside the charger port, look at yr creen andwait for car kit to turn off. if ur phone turns off, dw. turn it backon adn dont rub the area u were rubbing wen it turned off.
once car kit turns off, it most likely will turn back on, repeat thisstep. eventually,it will go away forever.
it took about a day for the car kit to stay away completely for me.
trust me, i've been were u are. i tried everything and it never worked. then wen all hoped seem lost, at 11:30 at night, i found this and it worked beautiful.
also, u dont need to use a paper clip, anything metal will work. but paper clips the best because of there size.=]
Jul 01, 2008 | LG VX8300 Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
Car kit
You don't mentioned your cell type and model. You will get the solution definetly but before that I have to know that.
Jan 08, 2008 | Cell Phones
Car Kit mode on
Have you used the start up mode on your phone? Take out the sim card and restart the phone on off line mode then close and when you turn on your phone with sim card restart in general mode.
Dec 06, 2007 | LG VX5300 Cellular Phone
Car kit mode???
The Car Kit message is usually caused by corrosion in your charging port. Yes, holding * may revive the phone, but your best bet is to get some contact cleaner and a toothbrush and clean out your charging port.
Sep 25, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
123 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
