I don't have the remote control to the film projector that is hooked up to my Compaq computer. How can I operate the film projector manually?
  • mjbenya Feb 14, 2009
    I have the same problem
    With a HP Media Center 7680 no screen, just 2-short beeps and one long beep pause and it repeats help me please
My desktop after booting makes two beeps and a long non stoping beeps
Posted on Jan 14, 2009
Projector only in stanby mode does not switch on
This projector provides two different remote control codes; the factory-set, initial code (Code 1) and the secondary code (Code 2). This switching function prevents remote control interference when several projectors or video equipment are operated at the same time.
When the projector is operated in "Code 2," both the projector and the remote control must be switched to "Code 2." To change the code for the projector:
Select either "Code 1" or "Code 2" in this Setting Menu.
To change the code for the remote control:
Press and hold both the MENU and IMAGE buttons together for more than 5 seconds. After changing the code, make sure the remote control operates properly.
Remote control
Press and hold MENU and IMAGE buttons for more than 5 seconds.
You can change the brightness of the screen.
High ...... Brighter than the Normal mode
Auto ...... Brightness according with the input signal
Normal ... Normal brightness
On start
Note:
•When different codes are set on the projector and on the remote control, any operation cannot be made. In that case, switch the code on the remote control to fit the code on the projector.
•If the batteries are removed from the remote control for a long period of time, the remote control code will be reset.
Mar 12, 2013 | Office Equipment & Supplies
I have a hp compaq laptop. i used properly before installing new operating system xp service 2 . but don't use my laptop and my epson projector because automatically don,t display my laptop and...
PC Projector first and Computer next. Usually if the projector powered on after computer you need to use Function keys on laptop normally Function and F4 buttons when pressed simultaneously the computer screen projected through projector. Function keys are identified by green lettering on them.
If you power on projector first and then the computer while they are connected through cable this problem may not arise. Try this and and also Function and F4. This usually fixes the problem. Let us know if you still have problem! good luck!
Sep 10, 2011 | Computers & Internet
How do you hook up cable tv to my epson powerlite 830p lcd video projector
To hook up cable tv, you will need to have the cable running into a vcr 1st, then run either your s-video cable or audio video cables into the projector. Press the Source Search button on the remote control or the projector repeatedly until you see the image you want to project on the screen. The projector has two Source buttons.
Use the Computer/Component button to switch between equipment
connected to the Computer/Component ports.
Use the Video/S-Video button to switch between equipment
connected to the Video and S-Video ports.
? The remote control has four Source buttons. Use them to switch
between devices connected to the ports identified on each button.
(The PowerLite 830p does not support EasyMP.TM)
You can preview all sources on one screen to help you select the
desired source. (Allow a few seconds for the projector to sync up
after pressing the button.)
Feb 01, 2011 | Epson PowerLite 830p Multimedia Projector
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Does a kodak slide projector hook up to a pc
No way! Kodak discontinued its slide projector line long before computer interface. The projectors are mechanical and analog. Maybe you can connect your remote control cord to some kind of computer interface. I know there are dissolve units available that will perform basic functions, but none that are PC-compatible as far as I know.
Oct 01, 2008 | Kodak Office Equipment & Supplies
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
Input 1
We have a similar problem with our sharp projector at church where the remote is on a long cable up to the projector as it is too far for the infrared. Sometimes it quits listening to the remote and we've found that unpluging the remote cable and plugging it back in restores the operation. Apparently, the long cable introduces noise into the remote input and gives it illegal codes sometimes.
Does yours only do this with that one button?
Hope Ya Fix it! Grace and Peace to you....
Jan 07, 2008 | Sharp XR-10X Multimedia Projector
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
