Question about Olevia Televison & Video
No signal when hooked to cable - Olevia Televison & Video
    Top Expert:
  • Olevia Master
  • 14,553 Answers
Hooked direct or with a box and hence to what connection on the set, there are different places and ways to hook up.
If no signal look first to see if a DVD player works by connection to one of the rear audio video inputs, this rules things out and offers a possible way around some issues.
Posted on Dec 11, 2012
Which cable outlet do i hook tv to for cable
most RV's have a selector box that takes signals in from all the different sources and directs them to the cable going into the TV. Should be marked "To Tv" or something similar. Then you just select the source as Cable.
Feb 28, 2015 | Keystone 2014 Outback 277RL
Sanyo gxba
u cant.......the antenna gets only over the air signals while the cable are actually wire transmitted signals meaning if its cable transmission u want u will have to consult the broadcast provider to hook u up with there particular signal cable to your tv thats what is called cable tv a reason ya antenna cant receive cable signals is compartibility
Jul 19, 2013 | Televison & Video
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
Used to be hooked to satelite ,now cable and says
Unplug,replug the cable box about an hour later,let it reset itself.The box will reboot itself,and upgrade the software.the signal should work again,not the cable box is dead must replaced.
Apr 26, 2010 | RCA L32WD22 32 in. LCD HDTV
No signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Dec 11, 2008 | Polaroid FLM-323B Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Lost the cable signal
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
May 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Thanks!
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
83 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
