Question about LG Televison & Video
I cannot connect my LG smart TV to my sky wireless router
The television has built in wifi but I also have the tv connected to a network plug in. The tv will find my router but when I enter my pass key it just returns saying not connected
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
  • 96 Answers
SOURCE: No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Posted on Feb 10, 2009
  • 40 Answers
SOURCE: Not able to connect to internet, using wireless router (SKy),
One of the things that I have seen that might fix this problem is running a program called winsock fix. What this does it reset/rebuild your network config on your laptop. You will need to download this program from the other computer and then take it to the laptop via thumbdrive/cd. Here is the link. Hope it helps.
http://www.snapfiles.com/get/winsockxpfix.html
Posted on Apr 10, 2009
  • 34 Answers
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Posted on Oct 28, 2009
How do I get my LG smart tv to connect to Wifi
change your WiFi security setings in your router from WPA/WPA2 to WEP.
Go back to the Smart TV and reconnect to your network with your selected security key.
It may be less secure but it may be the only setting your tv will recognize.
Sep 11, 2017 | LG Computers & Internet
Wired network is not set. Do you want to set wired network?
the tv should be plugged into a router, something that has a dhcp server. does your modem have a router built into it. without dhcp the smart function on the tv won't work. and that would take care that message, the tv just looking for internet access
Aug 23, 2015 | LG 42LV5500 42 in. LCD TV
Connect my broadband my finlux smart TV
If you TV is internet ready then you can plug a network cable directly into the port on the back of your TV from the router. If you have a TV that is WiFi capable then you will be able to navigate through the menus on your setup screen to get the to work wirelessly. You do have to have a wireless router for this though before searching for a wireless network.
Feb 27, 2015 | Finlux Televison & Video
How can i get my smart tv to connect to the internet it is already connected to my wifi but when i click to connect to the internet it comes up no internet connection?
Check to see if your laptop or phone gets online via wifi to see if wifi is on the net, and try rebooting your wireless router by unplugging, then plugging in. (do not press "reset" button on router)
Feb 26, 2015 | Televison & Video
How do I connect to the smart tv
I assume you want to connect your smart TV to your network (e.g. to get Internet access for NetFlix).
Depending upon the precise model, it will support WiFi or wired Ethernet (or both). If your TV supports a wired connection, that will provide the best performance. All you need is a spare port on your router/switch and a straight-through network cable.
If your TV supports WiFi, you'll need to get into the its setup to enter the settings matching your home network - that is, you must choose the SSID (essentially, your WiFi network name; so your TV connects to your network and not your neighbor's) and wireless security information.
Feb 13, 2015 | Smart Computers & Internet
Cannot connect to my wireless network
Recheck your router to see if the mac address of the TV is listed on the wifi setup page. On the TV, make sure the router password is entered correctly
Jul 23, 2014 | Hisense 50 Class 1080p LED Smart HDTV -...
I cant connect my WiFi router to my Hitachi smart TV
How do I actually delete the numbers in my DNS server
Dec 26, 2013 | Computers & Internet
Can I get help with connecting my smart tv to internet as its not working for me thanks a million :)
Hi, commonly these TVs use a network cable for connecting to Internet through a router, another TVs are wireless enabled, in this case you need a WiFi router to get Internet in your smart TV. The process is similar as you connect a computer to Internet but the keyboard of your TV is the remote control, some smart TVs can work with standard wireless keyboards and mices to surf Internet as with a computer.
Nov 01, 2013 | Televison & Video
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
Televison & Video Logo
436 people viewed this question
Computer Repairing
Computer Repairing
