Question about Home
Rover75 2.5 v alternator gets very hot
Alternator gets very when in use goes cold when not in use
    Sergeant:
  • 462 Answers
Sounds like the bearings are bad
Posted on Dec 12, 2012
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
Battery drain when weather is warm or hot.
what paying attention to the voltage regulator
cannot see amy reference to it being checked/replaced
if it is part of the ECM then replace the ECM
May 17, 2017 | 2004 Honda Accord
SINGLE VALVE SHOWER FAUCET TURN ON TO GET HOT WATER ONLY GETTING WARM WATER LUKE THE OTHER TUB AND SINK FAUCET COME OUT HOT HELP PLEASE
I can think of a few possibilities. 1) Something is blocking the hot water in to the mixing valve. Fixing this would probably mean cutting out the valve (then redoing the water lines with a new valve (possible option)).
2) The hot water line is losing too much heat going to this second faucet. (If the two tubs are on different floors this is more common. Many places are plumbed with one line with Ts to all fixtures.) Insulating the water lines might help; alternatively an point of use water heater would help.
3) The hot water and the cold water in are reversed. (Test by leaving the water on full cold and full hot for a few minutes each.) If you get full hot when it should be cold, valves with a cartridge are easy to fix. Open the valve assembly, remove the cartridge and reinsert it after turning it around (side closest to you when you removed it goes in first). Otherwise, the incoming plumbing needs to be redone at the point where the cold and hot lines come into the shower.
I hope this helps.
Dec 15, 2010 | Price Pfister Home
I have installed a Grundfos CH2050PT pressure booster system at my home (3 stories). The pumps is installed at ground level and is connected to the main water tank (source of water). The pressure is...
it could be the differential in pressure between the cold water from your booster pump and the hot water from your solar water heater . the cold water which feeds your solar heater is probably being reduced in pressure by a pressure reducing valve . so what you need is equal pressure on both your hot and cold water system you could install a pressure reducing valve on the pipe thart feeds your cold taps etc valve set at the same pressure as the one on the solar water heater that would give you a balanced hot and cold water system
Dec 07, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Electric shower hot and cold
it sounds like the flow is too low and causing the heat chamber to overheat ( or the heat sensor is faulty and thinks it is too hot) is the water too hot before it goes cold?
Mar 18, 2010 | Home
Where do i put power steering fluid in my 1992 chevy silverado?
The power steering fluid goes in the power steering pump which is on the drives side of the motor below the alternator.It is black and has a twist off cap.The cap is a dip stick type.It has levels which will have a hot and cold level.If the engine is cold fill to the cold level.If it is hot then fill to hot level.Hope this helps.
Dec 20, 2009 | 1992 Chevrolet C1500
Boiler recycling when in DHC mode and water alternates hot then cold, back to hot every few minutes. Could it be pressure / flow rate.
First check pressure over 1 bar ok then-
1. check flow - is it adequate - a little less than the cold tap ok then -
2. does the boiler initially fire up on low hot flow but alternate as u say
If answers are 1. no but 2. yes then check for a furred up secondary heat exchanger
if 1. yes but 2. no [that is the water not the heating] goes hot / cold and if the boiler goes out when the water goes to cold then it's the diverter valve, either to replace or if it is one which has a internal diaphragm-replace that
Nov 25, 2009 | Water Heaters
Alternator runs hot when battery is connected
when you start the car you need to see if the alternator charge its supposed to 13,7 to 14.5 max it supposed to stay like that but the way our taking its probably charge ok when its cold and when the car get warm the charging goes down in the back of alternator our supposed to have the same voltage as the battery if not check the big wire in the back for corrosion if our not sure the wondition insted of opening the wire harness bring direct power from the positive side of battery to the big wire in the back of alternator and from the negative side connect to the metal of alternator after that if its still get to hot change the alternator if you think my solution is intelligent please rate it thats the way i would check our caqr in my shop thanks pierre
Jul 30, 2009 | 1997 Mazda Protege
Air conditioner runs hot after a few minutes sitting idle. get cold while driving but goes hot after i stop or come to a red light
Check the belt that is attached to the alternator make sure its not loose. If that's fine then you may be low on freon refrigerant. Have someone check the pressure levels in the high and low side of your system.
Jun 27, 2009 | 1992 Chevrolet Cavalier
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
