Question about Goldstar Gold Star Er710m 1.35 Cu Ft Microwave Oven
There is rust inside the microwave, ist it still safe to use
    Scholar:
  • 78 Answers
If the unit starts to spark then you can buy microwave paint but if it goes through the door or the base then a professonal repair is best,clean the rust with rubbing paper and coat with thin layers let each one dry and build up a good layer of paint,hope this helps.
Posted on Dec 11, 2012
Why is the inside panel of my microwave rusting
There is a significant amount of steam given off during cooking. If your fan is not working or your vents are blocked, the moisture stays inside and hence; rust. You could repaint by doing a bit of sanding and using a tremclad rust paint.
Dec 13, 2014 | Kenmore Elite 79203 Microwave Oven
WaLL ge microWAVE RUSTED INSIDE
Frankly I'm surprised to hear that there is rust inside your microwave oven. Usually the inside is made with stainless steel and does not rust. Are you sure that it is rust? Could it be built up grime? If it is then use some Fantastic and wipe it away.
Good luck
Mar 21, 2014 | GE Microwave Ovens
Microwave safe to use?
If the microwave oven is not arcing on the inside, and seems to cook fine then yes it is okay to use.
Aug 16, 2012 | Samsung MW1030WA Microwave Oven
Microwave safety after repainting
Too generic...Did you use the high-temp appliance enamel recommended, or a spray...or worse?
Was the rust inside where it can contact food through the circulating air, or on the outer body?
First thought based on how I read the question: Never use that machine again...but that's based on the word "in" instead of "on my microwave".
If the rust was around the door frame, outside the seals, and you used an enamel (of course) then you may be OK...but...
Considering the fact that a cheap microwave is a drop in the bucket when compared to your family's health...Why risk it?
Mar 29, 2010 | Welbilt MR622W Microwave Oven
Rust marks on inside trim
IF YOU USE THE MICRO WAVE ALOT WHEN YOU COOK SOMETHING THE STEAM FROM THE FOOD BUILDS ON THE INSIDE AND CAUSES THIS PROBLEM. THE HINGES ARE OPEN AREAS WHERE THIS STEAM CAN COLLECT. NOTHING TO WORRY ABOUT
IT'S JUST ONE OF THOSE THINGS THAT HAPPEN
Sep 15, 2009 | Samsung MW5592W Microwave Oven
Rust inside the microwave oven
This is just okay but if you're quite doubtful you may bring this to any appliance service center for repaint
May 15, 2009 | KitchenAid KCMS145J Microwave Oven
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Nov 22, 2008 | Panasonic NN-T990SA Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG microwave oven
As long as the waveguide itself isn't damaged, you should be able to replace the shield without issue... That shield only prevents food from splashing onto the waveguide itself and is not part of the microwave RF protection... Check your local hardware store for touch up paint.. shouldn't matter what brand as long as it contains rust inhibitors.. Good luck...
Aug 22, 2008 | LG Microwave Ovens
Goldstar Gold Star Er710m 1.35 Cu Ft Microwave Oven Logo
150 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
