Question about LG 47LE5400 47 in. TV
Need to move LG Closed Captioning from Middle of Screen to Bottom of Screen
How do I move Closed Captioning from the middle of the screen to the bottom of the screen on an LG TV?
  • 31 Answers
SOURCE: 50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Posted on Mar 10, 2008
  • 4234 Answers
SOURCE: LCD TV
This set should still be under warranty. Inquire about warranty service. DO NOT open it up as that would void the warranty. There is a problem with either the logic board or the panel itself. In either case, it will be covered under warranty.
Dan
Posted on May 28, 2008
SOURCE: LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Posted on Aug 12, 2008
  • 92 Answers
SOURCE: purple line down middle of screen
I could do with a digital photo to be sure, however it sounds like the LCD panel itself has failed.
Sorry.
Posted on Mar 28, 2009
rlamkin
  • 44 Answers
SOURCE: black bar down middle of screen
these cables are machine installed on the panel itself, not user fixable. however, the cables are mounted to a circuit board at bottom of the screen. to reach they you need to remove nearly all the support structure and boards at the bottom of the panel. there are a number of sensitive parts under there and they have black 'licourus' on the chips to dissipate heat. good luck.
Posted on May 05, 2009
Black box in middle of screen jvc
That is a text box and you can turn it off from the closed captioning button on your remote or from the closed captioning sub menu category in your tvs menu.
Dec 25, 2010 | Televison & Video
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
There is a black box in the middle of the screen
usually black box is for closed captioning.There probably is a button labeld "cc" on the tv remote and possibly one on cable/sat remote if using.
Sep 13, 2010 | LG Televison & Video
Some channels on direct tv have a black rectangle
Either your tv or your directv receiver is on the text mode of the closed captioning function turn closed caption off and this will disappear.
Oct 15, 2009 | LG 42LC2D 42 in. LCD HDTV
My tv has a black square in the middle of the screen.how do i remove it
thats your closed captioning. on your remote, there should be a button on your remote to remove the closed captioning or to change the captioning type. Look for the "C.C." Button. press it. the closed captioning type will change. press again and again untill there is no text or it says "off or None"...
Hope that helped.
Aug 14, 2009 | JVC AV-32D305 32" TV
BLACK BOX ON TV SCREEN
check the closed captioning setting. I black box in the middle is one of the settings. Set CC to off.
Jun 02, 2009 | JVC Televison & Video
Jvc 48in projection tv
Somehow you have turned on closed captioning in TEXT mode. Navigate the setup menus to find the closed captioning options and turn it off.
That should resolve the problem.
Dan
Mar 20, 2009 | JVC AV-48WP30 48" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
LG 47LE5400 47 in. TV Logo
61 people viewed this question
Computer Repairing
Computer Repairing
