Question about Oreck Sanapathic DMS2000 Handheld Steam Vacuum
How to open water tank to fill.
Forgive my apparent stupidity, but I cannot figure out how to open the gosh darn water tank. The instructions have no diagrams or pictures, and read: "Release the tank using the red release button and extract very carefully" Okay, I can do that. Then, "Unscrew the cap to 90 degrees to release the bayonet coupling leaving the floater tube (permanent fishing tube) inside the tank, and fill the tank directly from the tap." It might as well be Greek, to me. HELP!
  • transcriptte
    transcriptte Dec 11, 2012
    By the way, this product is not a vacuum, it's a steam cleaner.
  • transcriptte
How do you put water into the tanks for cleaning. I see the 2 in 1 tank but can't figure out how to get clean water into the reservoir>
easy one the tank separates , there a clip that is on the flat side of the tank assembly, there is a handle to pick it up, half round handle. On the flat edge you"ll see the clip., unfasten the clip and the top and bottom separate, below is what looks like a hot water bottle,you fill that bladder with hot water, the outside plastichousing stores the dirty water, once full, a level sensor will rise and the vacuum will stop sucking! thats it!
Aug 16, 2014 | Vacuums
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    How much water goes in the vaccuum
    I have a simular model. Here's what I do.
    On the fill tank (that's the top tank), look on the front and you'll see where it says "Fill Line". Fill this with hot water first (so it doesn't foam up) and then add your cleaning solution. Make sure the lid on the bottom tank is on tight. It should snap in place. Top should also snap into place. Turn on and pull trigger and move forward a few feet, let go of trigger and solution will stop coming out. Do this a few times and then without pulling trigger, go over the same area you just did to pick up water. Repeat this until you are done. When the bottom tank is full, it will sound a little loader and higher pitch. Just empty tank and put back in and continue.
    Hope this helps.
    Sep 07, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    How do I attach the stair cleaner attachment
    1. remove recovery tank lid
    2. remove tank duct from front of tank
    3. slide flat end of hose into slot where tank duct was<open side up>
    4. place tank lid back on
    5. open water hose door on hood
    6. push waterline onto spickett
    7. clean your stairs.
    best of luck
    Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Vacumm Belt keeps coming off.
    stick a little bit of tape on the inner half of the spindle, this will put an angle on the belt and should prevent it slipping off.
    Dec 23, 2008 | Hoover Vacuums
    How do I fill it and start it?
    yes you should have got a cup with it to fill it then wait till it heats to steam
    May 26, 2008 | Scunci 900 Handheld Steam Vacuum
    Missing key part for proper function
    Get in contact with bissell on thier web site,
    They have a spares center,
    Nov 18, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
    Oreck Sanapathic DMS2000 Handheld Steam Vacuum Logo
    Top Oreck Vacuums Experts
    Jim Parker
    Jim Parker
    xalint1
    xalint1
    Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
