Toshiba tv makes static type sounds when I turn it on.
I have a Toshiba 19 inch portable tv . It works very well except for one thing. Every time I turn it on it make a loud noise like static and the pictures kind of jumps and this keeps up until I wiggle the cable at the back of the set. Then it will eventually stop until the next time I turn it on. Then it's the same thing. Do you think I need to solder in a new jack for the cable?
Thank you for your help.
    Novelist:
  • 140 Answers
I would replace or at least resolder the connections on the cable jack on the tv itself. You seem to have a loose ground or cold solder joint on the ground portion of the jack. Be sure as well to check that your actual cable has a good solid end on it as well.
Posted on Jan 13, 2009
My Hisense 32" inch tv has started making a popping sound and is static and it turns off then turns on and load then "pop" it off and it does it again then turns on stays on for about 10 mins with no sound...
Sounds like you have a bad power supply board. Either replace the TV or get it fixed (probably not worth spending too much on considering how cheap new 32" TVs are now).
Nov 29, 2013 | Televison & Video
Plug in head phones to tv/no sound
If no sound from speakers or headphone likely audio circuit issue but check to make sure main speakers not switched to off or external.
Nov 04, 2012 | Toshiba 19AV505DB 19-Inch Screen Hd Ready...
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Power light flashes 3 times and makes and alarm or chirping sound then nothing. its a 52 inch RCA hd52w59 itc222 chassis. I replaced cp150 and cp120/114 and also flyback transformer and still same thing? I...
Chirping sound is coming from coil on right side behind FBT, resolder then use Glue gun to glue on top of coil LL037,Make sure high voltage wire from FBT to Trippler is in Good this is what maybe causeing lines and fuzzy picture.Also make sure solder on all pinns of FBT are good.
Sep 22, 2009 | RCA HD52W59 HDTV Projection Television
High audio static on all but one channel of my RCA TV
had this problem for a while only just found the cause, its either your tuner flipped out which means you just neded to retune the tv and it should be fixed if not that there was this setting i found still not sure what it is or means but you could select these letters i think there was S, BG and some other ones but i changed it to the top one which was BG and it fixed the static sound with the clear picture problem just stuff around with the channel settings and see if you have that setting hope that helped
Aug 16, 2009 | RCA Televison & Video
Tv picture and sound
Sometimes you just have to shoot the old girl.
Mar 13, 2009 | Televison & Video
Why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Mar 13, 2009 | LG Televison & Video
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Toshiba Cyclone CX 34862 Television
Hello winman1,
It sounds like your shutdown circuit is shutting down your set. This is done usually because one of the stages in the TV most likley the High Voltage section is drawing excessive current. I would suggest that you take your TV to a qualified repair facility. Since this type of problem is a sign of serious problems.
I hope this helps,
Thank you,
Shuttle83
Mar 23, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
