Question about True Refrigerators
My Micro Fridge is making noise
Loud vibrating noise
ngfam1
  • 639 Answers
SOURCE: Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • 5 Answers
SOURCE: loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Posted on Oct 08, 2008
  • 531 Answers
SOURCE: loud vibrating noise
may be screw left out
Posted on Apr 02, 2009
  • 531 Answers
SOURCE: Haier mini fridge runs very loudly!
some thing is wrong
Posted on Apr 07, 2009
TheMazz
  • 78 Answers
SOURCE: Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Posted on Oct 28, 2009
When it is lcooling it has now begun tomake loud vibrations.
it is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
Oct 14, 2015 | Maytag MSD2454G Side by Side Refrigerator
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Our Samsung fridge srs757dw is making weird noises(it hums loudly). When the Freezer door is open it stops but as soon as it closes the noise begins again. What do you think is the problem?
Sometimes this can be due to vibrations within the duct , possible that the ventillating fan is frosted and so makes the noise with the door closed. So shut down fridge for few hours to defrost and check.Also make sure there are no loose screws or clips on the back panel and the evporator section that can cause vibration.
Aug 30, 2011 | Samsung Televison & Video
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
192 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
