Question about Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow
I need to clean the post HEPA filter on the bottom of my Dyson DC 18. How do I go about doing that?
I just realized there is a HEPA filter at the bottom of the canister. How do I cean that filter?
    Top Expert:
  • 14,553 Answers
If it is one that can be washed instructions will be in owner manual or even on the outside of the ring that holds it in place, did that recently for a friend and if air is blocked there low or no suction and in some cases unit will shut off and seem to have total loss of power, motor overheats and thermal relay or breaker trips.
The unit had marked it could be washed in soap and water in the sink, look for instructions as if not meant to be washed it could be ruined.
Posted on Dec 11, 2012
5 Suggested Answers
DysonInfo
  • 107 Answers
SOURCE: Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
Posted on Nov 30, 2010
SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Posted on Oct 29, 2009
SOURCE: how to remove hepa filter
how do I remove hepa filter, and how many filters does it have?
Posted on Mar 11, 2010
  • 53 Answers
SOURCE: remove hepa filter
Turn the Dyson on its back as if you were servicing the beater brush and on the RH side you'll see the filter housing for the HEPA and a T-15 Torx screw. Remove this screw and then remove the cover for the HEPA filter.
Posted on May 31, 2010
Dyson problems
I have a DC-07 Animal and I have taken it apart many a time and cleaned at least the plastic parts. Its all modular. I would just make sure nothing is clogged.. Remember the Hepa filter is not washable just the sponge filter. So if you took out the filter and left in the Helpa filter I would order a new Hepa filter - its probably clogged by now! Beat of luck!
Aug 12, 2014 | Dyson DC41 Animal Complete Ball Upright...
How to change the post motor hepa exhaust filter on dyson dc 15 animal vacuum ?
Hello, this is Ava with Think Crucial.
You may refer to your User's Manual on how you may clean vacuum filters by clicking the link below.
Dyson DC15 Owner Manual
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 17, 2014 | Dyson DC15 Animal Bagless Upright Cyclonic...
My Dyson Ball DC 25 made very loud noise when I put the hepa filter back on. I just washed the hepa filter and it had been dried for more than 24 hours. After I took off the filter, the sound was normal....
It sounds like it could need replaced or there is something stopped up in it somewhere . Clean all the crevices in it dirt could possibly be congested in it . If it still does it after you clean it out change the filter .
Oct 06, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
How do you get the clear plastic housing off to replace Hepa Filter on a Dyson DC 18 ?
Don't take the clear plastic housing off. The lower hepa filter is not meant to be cleaned, only the top filter needs to be cleaned, every three months. I just talked to the Dyson rep about the same issue.
Jan 23, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
Remove hepa filter
May 27, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to remove hepa filter on dyson 18
Nov 18, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
I have a dyson dc 17 what is the best way to thourghly cleaning , so I can get better suction , also do you have a instruction manul to. I seem to have misplaced mine thanks
The first step towards improving the suction is to clean the circular HEPA filter. The filter also houses a circular sponge which should be rinsed and dried before putting it back. Check the HEPA filter to see if it needs replacement -- will look muddy! Another quick check is to remove the HEPA filter, run the vacuum cleaner momentarily in upright position to check if suction is restored at the hose end.
After doing this if suction is still poor or non existent, you should detach the transparent canister - a bit tricky since the release rod for the flap has to be aligned when you want to reassemble the unit.
Once the canister is removed, you should check and clean the center tube/shaft for any clogged dust (use a wire coat hanger if needed to pry out the dust). This tube gets clogged if the vacuum cleaner was used to pick up damp/wet spills etc.
Sep 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Want to replace HEPA post filter
http://www.dyson.com/customercare/manuals/us/dc07_manual_us2007.pdf
here is the link to your owners manual. scroll down to page 6 it shows you the filter to clean and how to take it aprt.
Jan 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow Logo
182 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
