Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
I cannot upload via FTP, I have a motorola sgb900
It seems there is a problem with blocked port in my motorola cabelmodem
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
Set up a port trigger for FTP in the "Gateway" section on the "Port Triggers" page. Click on the "Custom" link at the head of the page.
Enter these values
Name FTP
Enable checked
Protocol TCP
Port Range 21:21
Session Chaining TCP/UDP
Session Interval 600
Address Replace Disable
Multi Host Yes
Click Add, then Apply.
You should be all set. Either that, or you could turn off the firewall.
Posted on Feb 01, 2009
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
Tip
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
on Feb 08, 2010 | Computers & Internet
FTP ports being blocked on my dell vostro 200
FTP uses ports 20 and 21. These ports may be blocked by your antivirus software or possibly your hardware router/firewall if you have one.
Apr 29, 2012 | Dell Vostro 200 Desktop Computer
Cannot upload pictures to an ftp site
You would open ports 20 and 21, and that would allow FTP transfer in passive mode. (Windows DOS FTP client does NOT do passive mode - so don't use that for testing)
Mar 18, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My computer shows my sgb900 with a good signal but wont connect i have a compaq laptop running 32 bit vista
Please check the security feature which you have enabled on sgb900. I dont think that running vista or Xp will make any change.
Regards,
Amit Kumar
Mar 16, 2009 | Arris SURFboard SBG900 Wireless Router...
Not transfering
If transfer blockage is only when you use FTP on Net.
Check if windows firewall is activated and if FTP protocol on port 21 DTP is activated.
Check if any other firewall/antivirus/security SW is configured to block transfer protocol.
Jan 11, 2009 | Computers & Internet
P2P Blocking
Who is the Admin for the Service in your Building, or if you hacked, you might get in trouble, it's not hard to do, check first and let me know, your bandwith is the Culpit, and yu need special PERMISSION
Aloha
Kahuna
Jun 01, 2008 | Computers & Internet
Uploading pictures
You can buy a data cable, but you get just as good a quality if you email them to yourself.
Apr 10, 2008 | Motorola Mobility i850 Cellular Phone
Limewire Can't Connect-Firewall Issues?
right mouse on your firewall and allow communication for the process (LimeWire.exe)
Mar 31, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
358 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
