Question about HTC Cell Phones
Keep getting dial tone on my phone, unable to receive or send calls
I cannot make nor receive any calls, i keep getting a dial tone.
    New Friend:
  • 9 Answers
Step 1:
try turning off the phone taking the battery out for 15 seconds then re inserting it and turn the phone back on
Step 2:
if that does not work then try to factory reset it
Step 3:
then if that does not work take it to the store and ask them to troubleshoot it
Posted on Dec 11, 2012
  • 13 Answers
SOURCE: Phone keeps sending message
see if the message is in the drafts folder or the sent items if so delete phone will stop sending
Posted on Jan 20, 2008
SOURCE: fax tone when i dial someone
i need v3i s internet setting
Posted on Feb 06, 2008
SOURCE: Just purchased a xphone gold dual sim tri band
LIK A ****
Posted on Jan 22, 2009
Bajanguru
  • 7752 Answers
SOURCE: No dial tone at my end when I ring a certain number even though the number I'm calling is ringing, also really slow to connect. all other numbers are fine
dial tone but mobiles ahve no dial tone when making or receiving calls.....
Posted on May 30, 2009
feelfemi009
  • 277 Answers
SOURCE: Nokia N72 mobile phone, am unable to hear dial
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Posted on Jul 11, 2009
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
I keep a dial tone, even when I dial a phone number...can't make an outgoing phone...I keep getting the dial tone. can you please help?
1) make sure is the phone is working good
2) there are tone dial
3) see the steps before o.k see ,if there are another phone having the same problem. The problem is service provider.
4) eliminate any background noise., mute the cordless handset before dialing.
God bless you
Sep 26, 2012 | Lands Phones
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
I'm unable to receive or send faxes
Are you sure the line is good? You can try a plugging a telephone into the line to check it.
If you press the "hook button" (or whatever it is called on that machine) do you hear a dial tone?
is the phone cord plugged in snugly and in the proper jack on the machine? Is the cord good?
These are a few things to try.
If all of that checks out, then the phone board on the machine is shot.
May 26, 2009 | Panasonic PANAFAX UF-6000 Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Jul 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Fax machine wont send or reiceve
Check to see if you have a dial tone. If not, plug a regular home phone into the jack in the wall and see if you can call it or dial out. You might have a dead phone line.
Apr 22, 2008 | Office Equipment & Supplies
Cell Phones Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
