Need to install savin 8025 photoconductor/developer and reset
Have "replace photoconductor" on my Savin 8025 and need installation instructions and also how to get into service mode and reset counter
drichards
  • 87 Answers
SOURCE: SAVIN 3515MF
open the right door. Open the front cover. Remove the toner assembly, not just cartridge. Unplug wire, pull out.
Posted on Apr 21, 2008
SOURCE: need to find part #'s, parts, and service manual for drum unit,etc
I have Ricoh part numbers for the Aficio 3025, which is the EXACT same machine, using the EXACT same parts. And I assume you mean upper and lower "fuser" rollers.
Photoconductor unit P/N B205 0151
Hot Roller P/N AE01 1103
Pressure roller P/N AE02 0161
Posted on Apr 17, 2009
savindude
  • 175 Answers
SOURCE: resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Posted on Jun 29, 2009
savindude
  • 175 Answers
SOURCE: PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Posted on Jul 01, 2009
  • 143 Answers
SOURCE: savin 816 photoconductor troubleshooting
Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear the PM Counter.
Posted on Sep 01, 2009
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin 816 photoconductor troubleshooting
Enter the SP mode.
Sep 01, 2009 | Ricoh Aficio 250 Copier
AFTER PHOTOCONDUCTOR REPLACED PAGES ARE BLANK
IF you replaced the entire PCU, make sure you pulled the plastic tabs from the unit and removed the protective paper from the drum area. I don't remember if the new PCU comes with developer pre-installed.
If you replaced the drum/developer, it is common for the lower developer unit drive gears to wear down and break off some of their teeth.
Hope this helps.
Jun 30, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Resetting the photoconductor unit
You need to enter service mode and the # is SP 5-912-1 set this to 0 (to get in to service mode press in sequence clear modes 1 0 7 and hold red stop for 5 or so sec. At the top of the screen should be direct SP highlight this and press the 59121 and it will take you right there.-Carl
Jun 28, 2009 | Savin 9935DP Laser Printer
Jun 28, 2009 | Ricoh Aficio 450 Copier
Need to find part #'s, parts, and service manual for drum unit,etc
Apr 17, 2009 | Ricoh Office Equipment & Supplies
Savin 2527 indicates toner empty
i would suggest make sure the toner is the correct type, make sure when you install the cartridge it is tilted a little so toner will be towards the cap.
change your photoconductor unit.
Jul 19, 2008 | Savin Office Equipment & Supplies
SAVIN 3515MF
Mar 12, 2008 | Office Equipment & Supplies
226 people viewed this question
jasbo
jasbo
