Question about Moen & One Handle Tub & Shower Faucet
How do I remove the caridge from moen 87559. can't get the retaining clip out because black rubber ring is actually above the edge of the clip. moen says use wrench to remove the black ring but it
  • 4 Answers
SOURCE: moen positemp cartridge won't come out of brass body housing
I used ViceGrips on the shaft, and stuck a straightblade screwdriver between the ViceGrips and the brass shell. A little prying, and it popped out.
Posted on Feb 07, 2009
  • 129 Answers
SOURCE: moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Posted on Sep 29, 2009
  • 35 Answers
SOURCE: Moen single stem bathroom basin tap (25 years
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Posted on Feb 23, 2010
  • 3 Answers
SOURCE: allen head wrench size
try 1/8
Posted on Apr 08, 2010
SOURCE: we are trying to put the retaining clip back in
The Cartridge probably isn't in all the way. Pushing it in by hand doesn't always seat it properly.
Make sure the clear plastic is centered in the gap where you push the clip in, then a few gentle taps with the wrench, followed by pushing around the edges (the black part) with a flat-blade screwdriver gets it all the way in.
If the cartridge is aligned and seated right, the clip should slide right in. If you have to force it, the cartridge is not in right.
Posted on Nov 09, 2010
How to remove headlight housing 2001 FLSTC
To remove the headlamp housing assembly disconnect the wiring harness and then remove the bolt underneath the housing and ligt the housing off the mount.
To change headlamp bulbs:
2001 FXSTD, FXSTS and FLSTS Models
Remove the trim ring screw and then the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
unhook them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb, replace the bulb and re-assemble all.
2001 FXST and FXSTB Models
Loosen the trim ring screw and remove the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
FLSTC and FLSTF Models
Except for HDI motorcycles which have a Halogen bulb similar to FXST the FLSTC and FLSTF motorcycles have a sealed beam type headlamp. HDI headlamps also contain a position lamp bulb that is found under the headlamp assembly's rubber boot.
Remove the trim ring screw and then the trim ring, being careful not to bend the two tabs that hold the
top of the trim ring in place, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
May 17, 2014 | 2000 Harley Davidson FLSTC Heritage...
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
The moen shower pullout type hot/cold valve will not slide out of the main valve body even after the retainer clip has been removed. I found some corrosion on the retainer clip and I have sprayed the area...
Howdy, those can be like pulling teeth. The wd40 will not help that much as it is not a robust solvent. I suggest letting some liquid wrench sit overnight on it and then pulling real hard. Good luck:)
Regards,Farmerbear
Aug 31, 2010 | Moen Home
How to change a headlight bulb on a 2002 Harley Davidson Dyna Wide Glide
REMOVAL
Do not ever touch the quartz bulb with your fingers as fingerprints will etch the glass and cause the bulb to fail prematurely.
FXD, FXDL, FXDX Models
Loosen the trim ring clamp screw and nut, remove the trim ring, pull the connector block from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to unhook and release them from the from notches in the headlamp assembly, pivot the wire retaining clip away from the bulb aqnd then remove the bulb from the headlamp assembly.
FXDWG, FXDXT Models
Loosen the trim ring clamp screw and remove the trim ring, pull the wiring connector from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to unhook and release them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb and remove the bulb from the headlamp assembly.
INSTALLATION
Install a new bulb and assemble the headlamp components in the reverse of the removal process. Align the headlight when it is fully installed. When reassembling the headlamp ensure that the slots and tabs in the headlamp, adapter ring, and trim ring are aligned.
Jul 12, 2010 | 2002 Harley Davidson FXDWG Dyna Wide Glide
We are trying to put the retaining clip back in after replaceing the cartridge on a sink faucet Moen 87264? help!! it came out very easily but now it won't go back in no matter how hard we try
Apr 10, 2010 | Moen & Replacement Cartridge
I have a Moen kitchen faucet, model 87511, that leaks around the insert that the aerator screws on. can I remove it? How? Is there an ''O'' ring that can be replaced? Fred Winker
Unscrew the retaining ring that holds the aerator and "O" ring. Note the O ring may be made out of brass or rubber. If brass it must be inserted with the beveled edge "in" Replace the retaining ring, sealing the threads with a small amout of plumbers putty or teflon tape. You can get a a repair kit which contains everthing you'll need for a couple of bucks at most hardware stores.
Mar 11, 2010 | Plumbing
Moen one handle tub & shower is leaking from spigit
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
I have a Moen L4600 lavoratory faucet and I want to replace the cartridge.(http://www.moen.com/shared/pdf/instruction_sheets/INS072F.pdf) I am having trouble removing the transition collar to get to the...
that is a good one you have to be careful not to mark the plating.  what I do is get some rubber or heavy cardboard and put it around the facet.  then I use my channel locks on the ring .  you have to be firm.  There is a tool called a strap wrench for this aplication but I never liked it much.  something like the one you would use to change an oil filter.
Jun 21, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Can't get the retaining ring back in on MOEN Magnum Replacement Cartridge
Make sure that the stem is slightly pulled out or open then use the plastic insertion tool that comes with the new cartridge and a pair of pliers to push cart. all the way in. Try the retaining clip again. If still won't go, partially install the insertion tool and turn cart. back and forth til clip goes in. Hope this helps
Nov 30, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Nov 27, 2008 | Plumbing
Moen & One Handle Tub & Shower Faucet  Logo
124 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
