Question about Garmin GPS
Garmin rino 655t with batt charged it doesnt always turn on not makeing connection or ???????
I have a garmin rino 655t and sometimes when i try to turn it on it wont come on i check battery and it is over 90 percent i take it out and reinstall several times and finally it will turn on??????????????
  • edward whelan Dec 12, 2012
    called garmin they are replaceing with new unit
3 Suggested Answers
  • 4102 Answers
SOURCE: wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Posted on Nov 15, 2007
SOURCE: Garmin 750 - 90 days old
it's battery problem
make sure to charge it
Posted on Dec 25, 2008
Where is the plugin on the rino 650 garmin
You need to use the AC adapter or specific vehicle charging cable to charge the rino series. They plug into a different port on the unit.
Jul 21, 2014 | Garmin GPS
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
Wierd sound after incoming radio call, it happens after the other 655T releases the talk button.
The unit may have a release tone to alert the receiving set that the transmisition is over. Or you may be setup on a repeator netwqork.
Apr 05, 2013 | Garmin Rino 655T Topo Gps 2-Way Radio
My rink 655t won't recognize new contacts when they transmit. I can't add them as a new contact. My older rink 530 sees the 655t and has dded it as a contact. How can I get the 655t to add the...
Hi Michael,
May I suggest you join yahoo group SPECIFIC to your GARMIN RINO 655T, there you will get great advice and info, plus you can download manuals, diagrams and software, lots of goodies.
I hope this helps you.
Cheers,
Peter
Jan 12, 2013 | Garmin Rino 655T Topo Gps 2-Way Radio
My rino won't charge
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Nov 03, 2012 | Garmin Rino 530 GPS Receiver
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
I've got a pair of Garmin Rino 110 that we use when outdoors. Recently, with full batteries and clear skies in the desert, not surrounded by trees, mountains, buildings, etc... both of the Rino 110s...
  • That RINO should have no issues picking up satellite signals in the conditions you were in. If you were inside a building I may buy it but not in an open desert. Sounds like they are feeding you a line to me. I might try to get my money back on that one. One thing is for sure, you were in about the best conditions for using that unit. If it failed you then, it will more than likely fail you when your life may rely on it. It would seem that a different GPS/GMRS unit will be necessary to give you that security.
Regards, Tony
May 10, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
My rino always says searching for sattellites
Once your rino travels more than 600 miles from original satellite fix you need to - Go to main page / satellites / options / new location.
Should take about 15 minutes to locate new satellites.
Sep 09, 2009 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 530 battery wont charge
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Nov 15, 2008 | Garmin Rino 530
GPS Logo
299 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
