Tele doesn't turn on I just have a blue flashing light can this be reset but I don't have a remote?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Dec 12, 2012
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
Constant flashing lights
These lights flashing are an indicator that something is wrong with the unit. Once the problem is solved the following steps will reset the lights so that they stop flashing. If you don't believe there is an issue you can try these steps and it will reset if nothing is wrong.
1.) Turn the refrigerator and freezer to 0 this will cause them to turn off.
2.) Hold Super Freeze and Super Cool buttons down for 15 seconds.
3.) Return your freezer and refrigerator temperature settings back to what they were before you turned them all the way down.
If this doesn't stop the lights something is still wrong with your unit and it is informing you of this.
I hope this helps!
Oct 20, 2012 | Refrigerators
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
I need the RCA Blue Ray rtb1203 Remote Control code for a Direct tv Remote
You don't need a code when programming a Direct TV remote. Try following these steps. The process take a few minutes but it works -
  • Turn on your Blue-Ray and put in a disk.
  • Switch the mode to which ever input the Blue-Ray is using.
  • Hold down the "mute" and "select" button at the same time until the green light begins to flash then release.
  • On the keypad enter the numbers 9-9-1 followed by Satellite, TV, VCR/DVD, Aux,
  • Press the power button or which ever function you wish to use for you Blue_Ray such as play for the VCR.
  • Point the remote at you Blue-Ray and slowly press the "channel" and "key" button together until the remote turns off. Do this slow enough so as not to pass up the right code.
  • Once the remote turns off then you have found the correct code.
  • Press and release the select key to lock that code in.
Please note that if you cycle through all the codes and your remote does not turn off and the red light flashes three times then the code you need for your Blue-Ray is not available with that remote. At that point another remote would need to be used.
Regards, Tony
Apr 23, 2011 | Audio Players & Recorders
Como programar un control de dish a una tele panasonic
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Mar 05, 2011 | DISH Network IR Remote Control
I have a samsung rear projection tele. I havent used it for 12 months, i have just plugged it back in and the red standby light comes on at the front of the tele. When I press the power button on the...
means B+ over current protection shutdown. Problem in power supply.
However since it was not used for 12 months
the problem could be that the fan that cools the bulb is not starting when you turn the tv on. Blow on it to get it going or clean with compressed air. The fan could be clogged up with lint etc. It's on the rear left of the tv.
Dec 11, 2010 | Samsung Televison & Video
How do I turn off the change oil light on a 1994 corvette
1. Turn the key to “Run,” but don’t start
2. Press “ENG MET” on the Trip
the engine.
Monitor. Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The
“CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the
“CHANGE OIL” light stops flashing
and goes out. This should take about
ten seconds.
When the light goes out, the monitoirs
reset. If the monitor doesn’tr eset, turn the
ignition off, then try again.
Nov 18, 2008 | 1994 Chevrolet Corvette
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
