Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Declan Murray Posted on Jun 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Playback movies on PC
Hi, when I upload movies to my PC from the Exilim they always play fast as if in fast forward mode? any ideas?
Misty Hoffman
Level 2:
  • Expert 374 Answers
  • Posted on Jul 08, 2007
Misty Hoffman
Expert
Level 2:
Answers
374
Questions
0
Helped
110859
Points
534
Get on the internet and download the VLC player. Just do a google search for it and it is free. Works great on MAC as well as PC for movie issues.
2answers
I have a Panasonic omnimovie Pv-610 and only one of my vhs tapes plays in fast forward mode, how can I fix?
If you mean just the one and the rest then it was probably recorded in Extended Play mode and nothing can be done.
Otherwise please explain your issues in more detail.
My xbox remote won't pause during playback
I hate to say this but it may be time for a new xbox remote.
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
License key
Smart Movie Player 3.41
Play your videos on your mobile device, anywhere, anytime, you need just a few steps:
* Convert any video file on your PC into a phone-friendly video file.
* Upload video into device/memory card.
* Play the video in SmartMovie Player installed on your mobile device.
Features:
* Standard AVI format, allowing you to preview converted files on your PC.
* Player uses the phone screen in portrait or landscape mode, utilizing full screen size of the device.
* Rescaling of video to utilize full-screen area.
* PC converter allows you to split video file into multiple segments, so that it fits onto your memory card, if not entire, then cut to more parts - you may watch your favorite video in parts, e.g. while traveling to work/school.
* Support for subtitles - allowing you to watch movies in different languages.
* Friendly PC converter - preview videos on PC, select parts you want to convert, alter quality.
* Supports DirectShow codecs, so you may use video codecs downloadable from the internet.
* Very fast conversion; on standard PC conversion is 5x faster than video clip playback time. You'll convert entire movie in just a few minutes
* Bicubic rescale algorithm shrinks video to small screen size in best possible quality.
* Adjustable quality parameters for video and audio streams, allowing tuning target video to your needs.
* Customizable video Player (brightness, language, volume, and more).
http://rapidshare.com/files/79606223/Smart_Movie.zip
Hope this helps, Please Rate My Response! Thanks! Prem
Feb 14, 2009 • Nokia 6600
Playback of DSS file in AS-2300 version 7.3
Usually this means there is no sound card set up on the pc.
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
3helpful
3answers
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 • Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
