Question about HP OfficeJet 6210 All-In-One InkJet Printer
Can I get a replacement hinge for an HP J5750 Printer?
The left hinge broke so now cover wont close properly and printer will not pring.
  • 23 Answers
SOURCE: HP 3500 color printer
If you can see what is stopping the door from closing, and it appears to be on the right side of the printer near the top where the cartridge engaging pins are, and you remove all the cartridges and transfer belt and the door closes well, you may want to try this: There is a small silver screw at the top of the right corner of the case. When our front door would not close properly with the cartridges and transfer belt assembly installed, I took off the right side cover and took out that top corner screw. Then I slid the long white engaging rack that is on the lower right side of the printer toward the front door, which retracted those cartridge pins that are triangularly-shaped on their ends. Once the door would close properly with the cartridges and the transfer belt installed,and the pins engaged properly to open the cartridges as the door closed, I put the top corner screw back in and the side cover back on. I hope that helps you.
Posted on Oct 02, 2007
  • 21 Answers
SOURCE: Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
Posted on May 31, 2008
  • 62 Answers
SOURCE: officejet J5750 won't scan. Error message on
did you check this? you probably did but better post it anyway http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: Getting printheads to left side of printer to
Press and hold the resume button - the one on the right hand side
Posted on Oct 13, 2009
  • 11 Answers
SOURCE: Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Posted on Jun 13, 2010
Where to buy the Lexmark prestige pro top cover hinge of scanner
Lexmark doesn't sell or manufacture replacement hinges. If your printer is still under warranty, please contact our technical support team via phone so they can send you a replacement printer. If not, just remove the hinge and its assembly so you will be able to totally close the cover of the printer and be able to scan from the ADF.
Jan 23, 2013 | Lexmark 90T8005 Prestige Pro805 Wireless...
Left hinge broke on lexmark pro 905
Not a perfect fix, but this is what I did: There are 2 spring-loaded pistons located on the printer side of the hinge that cause this problem. I think there should be another piece of plastic that holds the top of the printer hinge down on these springs, but when this hinge is gone, the top of the printer is held upward by them. If you use some pliers to gently pull these spring-loaded pistons upward, you can easily pull them out, followed by the springs they cover. Once removing these, the top of the printer lies flat. The top is still unstable, but mine will now feed paper just fine and closes. Hope this helps! WebRepOverall ratingThis site has no rating(not enough votes)
Oct 23, 2012 | Lexmark Platinum Pro905 multifunction...
Lexmark pinnacle pro adf cover hinge won't close
Go to this link on You Tube and watch the revised video. It will correct the problem for you.
Jun 03, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
The hinge on the cover cracked. Can this be replaced?
I used an offset cabinet hinge & screwed it into the body of the printer, & the cover. The offset has to be jiggled a bit to open, but works fine on closing.
Otherwise, HP wants you to buy a complete new scanner cover.
Dec 07, 2010 | HP Officejet 6310 All-In-One InkJet...
The door hinges on my 3210 have broken. can i get replacement hinges
hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
May 07, 2010 | HP Photosmart 3210 Printer
The plastic hinge on the cover of my HP 3210 printer cover is broken and a nearby electrical connector has been disconnected. can you fix the problem or suggest someone who can.
Me 2 I was changing a the yellow cartridge and try to close the lid and POW the hinge on the right side broke. I got the printer opened and had to disconnect three ribbon cables the 3.5 mm jack and one 6 pin connector plug.
Apr 28, 2010 | HP Photosmart 3210 Printer
Parts for Brother MFC 8200D
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
Feb 28, 2008 | Brother MFC 8820D All-In-One Laser Printer
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
