Question about Sony PS-LX300USB Turntable
Every record skips in different places
Hello. I have had this turntable for a week and have yet to get a single track to play through without skipping. At first I thought it might be the vinyl itself, but I have tried 2 x 7"s and 4 x 12"s (2 of which played fine on my cheaper Pioneer turntable and 2 of which were brand new and unplayed) but each time I play a record it skips in a different place - if I play the record 5 times it will skip in a different place on each of the 5 playings. I've tried putting a 20p piece on the arm to add weight but this has made no difference. Does this turntable actually work? Please help. Thank you
  • Sony Master
  • 5,056 Answers
You should look for an anti-skate control on the turntable and adjust that. It will be a question of trial and error with it as there is no fixed rules for these. The weight on the back of the arm should be set to the weight of your cartridge.
Posted on Dec 16, 2012
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
Mar 05, 2014 | Technics Audio Players & Recorders
My brand new audio-technica AT-LP60 turntable has skipped on every single record I've played in it (even brand new ones). Always happens at the same spot - towards the end of the record, halfway...
hi,
Do one thing adjust counterweight on the back of the arm to 1.5gm or 2gm by rotating the counterweight. It will give some more pressuer on the styles and will avoid the jerking
ok
Aug 04, 2011 | Audio Technica AT-PL120 Turntable
My PL120 turntable purchase new skips often and will hardly work with music played at a loud volume
The first problem could be the stylus needs cleaning. Please shine some light on the stylus ( needle ) and see if it has picked up dirt from the record groove. This will prevent the stylus from tracking the song properly. Clean using a fine brush in the direction in which the stylus passes the record groove i.e from back of the pick up arm to front- NEVER SIDEWAYS.
Next check the counterweight adjustment at the back of the Pick up arm. The tracking force should be between 1.5 to 3 grams depending on the brand of the cartridge. What ever be the chosen weight the antiskating knob should also be set to the same number.
The skipping can also be because of heavy bass vibration traveling up the body of the Turntable.Good turntables have a floating suspension to prevent this. The tuntable platter will be suspended on springs.You can place it on a rubber Matt or move it away from the speakers ,esp: sub woofers.
Apr 06, 2011 | Audio Technica AT-PL120 Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
Arm's Weight
Not by design.
Tracking Force and anti-skate are preset and unfortunately not adjustable in many modern turntables . You want to be cautious with modifying it if only a couple of your records skip.
If you DO decide to try modifying it consder that the tracking force is in the probable range of 2-4 grams. In the old prehistoric days before T'Ts had adustable tracking and antiskate we would place a dime or penny on top of the cartridge shell to assert the stylus into the groove. THAT is a bad idea unless excessive record and stylus wear is unimportant to you.
Is there anything that might contribute to skipping (not level, scratches, warps, environmental vibrations, loud speakers nearby)?
Apr 01, 2010 | Audio Technica AT-PL50 Turntable
Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
Feb 02, 2010 | Audio Players & Recorders
I have a mid 1970s Sears turntable with am/fm, casette, and 8-track. It plays older vinyl just fine and even one new 45 but my new 33 skips a lot. Could it be the record, do I need a new needle, any...
My suggestion is ask a friend etc with a turntable to try the new LP and see if it bounces on there's. If it plays your old stuff it most likely doesn't need a new stylus. Records are records they don't make them any different to what they used to. Check the new LP, is it warped does it have marks where it jumps?
Sep 17, 2009 | Audio Players & Recorders
Only records 3 or 4 out of 10 songs
Please describe the exact model number and what it's doing wrong (skipping, I suspect). The tonearm setup is critical for proper tracking. Do it again with extreme care if mistracking is your problem.
I found one model online and a review with some sample of music. Quite interesting...
http://www.everythingusb.com/ion_ttusb10_usb_turntable_13231.html
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required to for a mechanism to properly track the microscopic undulations of the groove without skipping into the air or gouging it to death.
Some basics when recording from a turntable...
1) Place the turntable as far from speakers as possible on a solid surface that you will not touch during the recording
2) Keep the volume low enough that airborne sounds don't cause mistracking of the stylus *
3) Avoid anything that will cause vibration or movement of the turntable.
* If you have a subwoofer, turn it off.
Some advice after reading the articel: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
In general, the fewer the conversions steps in the analog domain, the better; and the fewer the bit rate conversions in the digital domain, the better.
Apr 03, 2009 | ION Audio Vinyl Recording Turntable
Ion ittusb turntable interference
Please describe the conditions under which the noise happens. Is it always the same place? Whic is it - static or some other kind of interference? Read the following. If you're using high speaker volume to monitor while recording you could experiment with identifying it as the casue by cranking it up to see if you can make it worse.
As with any turntable the following advice for this one will apply:
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required for a mechanism to rotate at a constant precise speed while properly tracking the microscopic undulations of the groove without skipping into the air or gouging it to death.
3) Avoid anything that will cause vibration or movement of the turntable. (Tip toe)
Some advice after reading the article: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
Mar 26, 2009 | ION Audio Vinyl Recording Turntable
Needle keeps skipping
It was the counterweight. I found the instructions a bit confusing for my feeble brain! :) I went back and tried again and must have gotten it right as no skipping now. It works great! I love it.
Jan 10, 2009 | ION Audio TTUSB10 Turntable
Sony PS-LX300USB Turntable Logo
287 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
