Question about RCA P61927 61" Rear Projection Television
Black screen with sound
When I turn on my tv, i have audio but the screen is blank and will come on in about 20 seconds but will be a rolling screen. then will go dark again. the blue screen will come up when i hit the menu
    Top Expert:
  • RCA Master
  • 14,553 Answers
A couple of things to try, Ist does the set work normally with a DVD etc connected to a rear input, if you are using a box for signal disconnect it and the set from power for a while and power both back.
The DVD idea is to know if problem is not present via the rear inputs and rules some things in or out, if set works that way there may be a simple way around the problem.
If when you call up the menu it is there, that comes from a different area inside the set and is generated within the set--still it is good news.
Posted on Dec 11, 2012
Testimonial: "Truly A Master At His Profession!! Knows What He Is Doing"
  • 3 more comments
  • Randy Stuart
    Randy Stuart Dec 11, 2012
    Okay Bud. All Components Have Been Unplugged For A Couple Of Hours. I Plugged The Power Back To The TV And Turned On The Dvd. Great Picture !!
  • SD Tech
    SD Tech Dec 11, 2012
    If the tuner input is still bad you can route the signal where the DVD is or if its ok now keep your fingers crossed.
  • Randy Stuart
    Wow Bud. It Works. So My Tuner Input May Be Bad ? What Causes This And Is It A Pain To Get And Replace It ? I Really Appreciate You Getting Back So Fast And All Of Your Knowledge In This
  • SD Tech
    TUNER in these sets is both expensive and may no longer be available, the option is rather easy if you have cable request a box with the audio and video jacks like your DVD should have, say dvd is on video one, connect the others from the cable box out to another input on the set say video two, watch TV by switching to that input and change channels with box remote etc.
  • Randy Stuart
    Randy Stuart Dec 12, 2012
    Great Bud. I Will Get With Comcast And Get A New Bow. Thanks Again For All Your Help.
ladywinn
  • 5138 Answers
SOURCE: plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Posted on Feb 19, 2009
ladywinn
  • 5138 Answers
SOURCE: screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Posted on Feb 20, 2009
  • 1030 Answers
SOURCE: tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Posted on Mar 18, 2009
  • 147 Answers
SOURCE: Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Posted on Apr 25, 2009
Shuttle83
  • 1139 Answers
SOURCE: wont stay on after power is hit
Hello, I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
? 3:16
Dec 20, 2015 | LG Televison & Video
Blank screen
if the screen is a dull deep blue and you hear audio perfectly its probably the Main board. If the screen is dark but you hear audio perfectly it would be the inverter. If you dont hear any audio then its the main board. You can get free assistance to determine which one it is as well as relacement boards from www.tvrepairworld.com
Oct 27, 2012 | Sanyo DP42848 LCD TV
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
Jul 29, 2012 | Vizio VOJ320F1A 32 in. LCD TV
Once the TV is turned on, the sound and picture disappears and replaced by a blank screen. If one turns it off again and on imediately the picture and sound returns. This may happen several times in a row,...
Could be ethier one the dish box or the tv itself have cold solders joints on the FBT-Flyback transformer.That the big black block of plastic with a red wire with a black cap hook to the CRT-(tv tube).Call ur tv Dish box customer service,get a replacement box.See, if this will solved ur tv problems.If not,than the tv must be taken aparts and must have tools like a soldering iron,a roll of solders,also must know basic soldering.Resolders all the coldsolders joints on the FBT for a better High voltages contact to the CRT-(tv tube).This problems,will be solved.
Dec 03, 2010 | Philips Magnavox 27MS343S 27" TV
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
My TV turns on but the screen is blank...got sound no picture...
its the slave invertor or if it has one its the invertor
Apr 20, 2010 | Proscan 32LA30Q Television
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Turn on and screen goes blank after 45 seconds
I found the problem was related to the lamp. Your TV power up but then the lamp would overheat and automatically shut down (audio and video) resulting in a dark screen with no sound. Once the lamp cooled (30 - 60 secs) it would come back on. Then overheat, turn off - recycling "eternally". A new lamp will solve the problem
Bye
Dec 28, 2009 | Sony KV-35S45 35" TV
RCA P61927 61" Rear Projection Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
