Question about HP Photosmart 8450 InkJet Printer
Flashing amber light in card reader area
Display alson has the code B9FEA939
Did you get this reolved, i am having the same issue?
Posted on Mar 07, 2013
Fiat punto 2002 stutters when driven
The amber MiL light, lights on a number of problems. You need to get it sorted, you could miss a serious fault, and cause More damage. Needs to go on a code reader. From past experience with Punto's, the stutter could be a ignition coil fault (quite common) or a spark plug, both will cause the light to come on. Good Luck.
Dec 27, 2013 | 2002 Fiat Punto
Alpha boiler cb24
Google Alpha boiler you should be able to down load a online manual with a ff chart in it . which should have codes in there for flashing lights .
Jul 29, 2017 | Water Heaters
2006 ford focus displays transmission malfunction with amber light intermittently, fluid has been topped up any ideas?
I would have the body computer scanned for trouble codes. A basic code reader may not access the body computer.
Aug 12, 2012 | Ford Cars & Trucks
Dell dimension 2400 diagnostic led lights abc=off,d=amber, please help
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm#1105412
Since that isn't one of the listed codes, it is important to see what the POWER LED indicates.
If it is Flashing Amber, most likely a bad power supply
If power LED is solid amber, then either the motherboard, or a expansion card in the motherboard has failed. Remove any expansion cards, (Modem, sound or video card) try booting again.
If no Change then a motherboard
Jun 26, 2011 | Dell Dimension 2400 PC Desktop
I have a PNY flash drive 2.0 g its read only because of incomplete files cannot format
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flash drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 29, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
2g attache optima pro black/amber went to write protected...how do I fix it?
2. Format
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Digital stills
The panasonic PV-L750 comes with an 8 MB Compact Flash card for storing digital still pictures.
To remove this flash card from the camcorder, open the cassette loading area using the "Tape Eject" button. The card is located inside this area. Find the "Card Eject" button to remove the flash card.
You will have to purchase a USB compact flash card READER to view and/or transfer the pictures to your PC's hard drive. You can purchase one at any computer supply store, or buy one online if you like.
Once you've transfered the images from the USB flash card reader to your PC, you can view and/or edit them with your favorite graphics image editing software.
~app
Feb 02, 2008 | Panasonic PV-L750 Camcorder
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP Photosmart 8450 InkJet Printer Logo
Seeker5211
Seeker5211
