Question about HP PRINTER,DESIGNJET 500 42'' InkJet
HP 500 designjet plotter Error Message 17:11
Hi, How I can fix this error?
H p designjet 500 repair 17:11 error code
Posted on Mar 07, 2013
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 27, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
antiochpc
  • 1314 Answers
SOURCE: System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
Posted on May 28, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
How to Fix Apple Safari Error 268d4?
Hi please see http://computerfixguide.com/safe-guide-to-remove-error-268d3-pop-up-permanently/
Oct 02, 2017 | Apple Computers & Internet
How to fix the following trouble message please thank you beforehand
This info is for technicians and explanations for the codes is limited to them
Jun 23, 2016 | HP DESIGNJET 500 InkJet Plotter Printer
Resetter EEPORM in the SERVICE MENU'.
Hi Pedrotti Mauro
Although the Designjet models are out of my support expertise, I found something that might hep you with the error 24:10 you are seeing. Please use the following link to take a look what I found:
Re Error message 24 10 on Design Jet 4500
As you can see, this was for a different model, but I image the solution will be helpful.
I hope this helps.
I work on behalf of HP.
Jul 01, 2015 | HP DesignJet 4000 InkJet Printer
I am still having a problem with HP designjet 500 Plus showing error 86:01 then writing so:Severe error: 0 x 8010003 task: tMech file: sequence.c line: 636
sounds like the printer is broken pretty badly. Is it still in warranty? Contact HP for a replacement, or else it's time to buy a new one.
Nov 11, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
Error 17:11 Hp 500 designjet plotter
error 17:11 no way related to DSJ 500.. Pl check
Dec 12, 2012 | HP PRINTER,DESIGNJET 500 42'' InkJet
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
I have error code showing E007 on Canon iR2016j copier. How can I go ahead to rectify the error. Pl advise necessary assistance
these means that you have trouble with fixing film in fixing assy.So... you need to change fixing foil.
Feb 22, 2011 | Office Equipment & Supplies
Hp designjet 500 plus 24"
HEYA
This error indicates that there is a problem in the Service Station Assembly (SVS). Either you have a paper left-over after a paper jam thats blocking the movement of the mechanism of the SVS or sometimes ink mounds around the Station if yes try cleaning it, or it could be a transient error that entails to turn the plotter off for a while and then turn it back on. If problem reappears and you are familiar in this plotter disassembly, check manually while the plotter is OFF the motion of the SVS gears; you can figure out the smooth movement.
In worst cases if problem persists i have to tell you that replacement of the SVS might solve your problem.
Hope this fixes your problem if not please reply
LONG LIVE THE GEEKS!!
Dec 08, 2010 | Computers & Internet
HP PRINTER,DESIGNJET 500 42'' InkJet Logo
280 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
