Question about Samsung Televison & Video
Samsung le46 lcd tv sound goes down to zero when turned back up returns to zero imediatly bar stays on scrreen showing zero
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Listen carefully:
The volume down is likely bad on the set, this happens a lot and I will explain why and what needs to be done.
All sets with exterior controls, volume, on/off you name it behind each plastic button is a tiny switch---a push switch that when released stops.
Bad ones develop not from age but poor quality,,,,that is a momentary switch, as long as held it should function and when released stop.
Be thankful it is not the sound UP as I have seen that, Menu, you name it.
Now to the proof and the solution, Someone has to gain access to that switch under that plastic button and remove it from the small circuit board it is soldered into---2 to four solder connections and remove the switch.
A ten year old with a soldering iron can do it.
With it removed power set back and see, if problem gone you have a few choices (really no choice if it was me) order and replace the entire board with all the buttons affected or DO NOT PUT THE BAD SWITCH BACK AND just use the set with the remote.
For the technical minded first the reason a remote will not stop this is buttons on the set have priority over the remote functions and YES you can test the bad switch and find it that way---I have seen ones not being pressed that read as low as 3 thousand ohms or less and that is bad=====there should be no reading across the two pins that are for that switch itself.
Let me know if you have questions, PS none of them sell the individual parts you have to buy the same poor quality board with another set of switches on it.
Posted on Dec 11, 2012
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: samsung le46 lcd tv sound goes down to zero and wont stay up
Under each of the plastic buttons on the set there is a tiny push switch--the plastic button activates it---it is a momentary switch and when the button is released it should stop its function.
A lot do not--fail: vol up is worst but can be any of them. The way to prove this is get at that switch (vol down in your case) which is usually on a small circuit board---unsolder the two pins for that switch and remove it.
If problem gone you know what it was---you really do not have to replace it as the remote should duplicate all functions of these switches---in some cases the remote will not control or stop this---front controls have priority over the remote.
Posted on Dec 08, 2012
My LCD tv loses picture for a couple seconds but then comes back on. How do i fix this?
Hi Noah, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
Apr 30, 2016 | Samsung Televison & Video
Volume goes to zero
sounds like you need to replace the buttons on the side of the tv. I can get you a part number if you will supply me with the full model code and version of your tv.
Dec 31, 2013 | Samsung LN32A540 32 in. LCD HDTV
Samsung le46 lcd tv sound goes down to zero and wont stay up
Dec 07, 2012 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
Oct 28, 2012 | Samsung LE-46A566 46 in. LCD TV
Sound
try to replace the (-) volume button it is defective so the volume will auto down..
after you replace that 100% works fine..
Apr 27, 2012 | Audiovox PLV16081 8 in. LCD TV
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Picture goes out, sound stays on
According the information I believe your backlight might went out. call 323-767-6030 I will go through with you for your tv.
Dec 14, 2008 | Astar LTV-3201 32 in. LCD Television
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Televison & Video Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
