Question about Samsung S24A300B Monitor
Samsung s24b300 not on optimum resolution
Not on full screen
4 Suggested Answers
MC707
  • 16 Answers
SOURCE: PC max screen resolution far below optimum of
I personally doubt you have a 2.1" monitor, since I have only seen 2.1" monitors in cell phones xD. Maybe you were trying to say 21".
Second, try to be more specific. Tell us your OS, graphics card, etc so we might be able to bypass useless questions.
Now to your problem, first of all make sure your graphics card has its latest drivers, if you have ATI or Nvidia card then you should look at their website, or look at your card's manufacturer website. Then, and only then, right click on the desktop and click on preferences (personalize under Vista). Then go to display settings and once there select your resolution. The best setting is usually the biggest resolution that appears on the list, though ONLY if your card got its proper drivers. If not, you will get a bunch of *probably* incompatible resolutions. Hope that helps.
Posted on Jun 11, 2009
budmrtn
  • 11361 Answers
SOURCE: when i turn on PC
Are you saying that the 1280*1024 @60Hz is not availabel at the display property on the PC?
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Unless there is problem inside the monitor, you should try this monitor on another PC to see if the resolution can be set at another PC.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 25, 2010
budmrtn
  • 11361 Answers
SOURCE: how to see the optimum
Native resolution: 1680 x 1050 @60Hz
and here:
and here:
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Posted on Apr 10, 2011
Samsung SyncMaster S24B300 is not in optimum mode of 1920x1080 60Hz as it should, but in 1360x768 ocasionally is starting up in 1920x1080 but most of the time in lower resolution mode, could FixYa he
Using our onchip Intel graphics we experienced the same problem, where the aspect ratio was displayed wrong using the native resolution of 1920x1080 at 60Hz while black bars show on the left and right side.
The problem was partly solved by using custom timing settings as you can find below:
Front Porch: 90 and 19
Back Porch: 148 and 22
Sync Width: 42 and 4
Active: 1920 and 1080
Scan rate: (auto 67.5) and 60
Then you just have to move the image down a couple of pixels using the buttons on the display.
Aug 27, 2012 | Computers & Internet
Samsung SyncMaster 2233SW Monitor "Not
The "native" resolution of the monitor is the "optimal" resolution -- it looks best to use this resolution.
So, right-mouse click anywhere on your Windows desktop "wallpaper".
Click Properties.
Click Settings.
Move the "Screen Resolution" slider to the recommended settings.
Click Apply.
Click OK.
Nov 21, 2010 | Samsung SyncMaster 2233SW Monitor
After 5 years with no problems, my Samsung SyncMaster 915N monitor is blank with the exception of an error message that says something about needing optimum resolution. At first we thought it might be the...
The optimum resolution for this monitor is 1280x1,024 @60Hz.
The resolution setting is done at the PC not at the monitor.
After 5 years, more likely components failure will be the filter caps in the power supply section, that will be the first thing to look for inside. You can see failed SAMSUNG monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 27, 2010 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
My screen is showing message "Not optimum Mode, Recomended Mode : 1024 x 768 60Mhz. ?
you need to change your video adapter resolution to this one,if you can`t see nothing in normal moe login in safe mode(tap f8 on boot)and change resolution then restart
Jun 13, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung S24A300B Monitor Logo
266 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
