Question about Brother HL-5280DW Laser Printer
Now initializing I replaced the drum and am now stuck with "now initializing" screen
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one.
did you do the reset procedure? if not it's in your owners manual under the section "replacing the consumables".
hth,
razors
Nov 29, 2011 | Brother HL 5250DN Laser Printer
I got a "drum error"
Its been a while since i have done a brother drum change but if i remember correctly dont you have to have the drum front cover open while pressing the clear/back button? Then i think it says new drum/ and you press yes?
Jun 03, 2011 | Brother MFC 7840W Printer
Installed TN360 Brother toner and now getting 6 "dots", evenly spaced on the right edge of each paper. The cartridge has been "rocked" and the corona wire cleaned.
More than likely you have some excess toner that is stuck on the image drum, thus the evenly spaced dots down the page. Examine the image drum to see if you see the stuck on toner. Take care not to touch the "glassy" surface of the drum. Use a lint free cloth to see if you can remove the spots. Do not use force as this can damage or scratch the image drum and then you will have scratch marks running down your page. If this does not do the trick you might also have to replace the image drum.
Mar 07, 2011 | Brother MFC-7340 All-In-One Laser Printer
How to change drum to a Brother Super G3 Fax Machine instruction state to change drum, and with door open, hit the clear button until "Replace Drum?" appears, then hit 1,,,,,,well there is no...
With door open, press "Options." Screen reads, "Change Drum?" Press 1 for yes. Screen reads "Accepted." Place drum/toner in, close door. Done!
Feb 03, 2011 | Brother IntelliFax-2920 Fax
The "Initial Setup" screen pops up and starts
replace your tac switches maybe one of the switch are defective.
Dec 22, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Display is stuck on "initializing..."
1. disconnect it from any other devices.
2. turn the printer off and unplug it.
3. plug it back in and try again.
Dec 16, 2010 | HP PSC 1610 All-In-One InkJet Printer
Brother HL-5280DW Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
