Question about LG Ovens
LG oven keeps melting relay
Oven relay get hot and starts to melt after using several times it burns up. Replace and it did it again replace the. I then replaced the top element( which is what relay keeps melting) and it is still having the problem.
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
  • 14 Answers
SOURCE: element ''melting''
paul,as the saying goes the dont make them like they used to,im sorry to tell you your elemant is on its way out dont be surpised if by the time this answer gets to you it is burnt out .sorry i could not give you better news.adrian ps.the elemant is melting please get it replaced.
Posted on Feb 14, 2009
mastatech
  • 478 Answers
SOURCE: replace element in top of oven of an f241 candy cooker.
There should be two screws at the inside back of oven. However, once you have the new element look for the holes in the new one
Posted on Mar 20, 2009
  • 417 Answers
SOURCE: Need to replace heating element
Have you tried www.appliancepartspros.com
Posted on Jan 15, 2010
SOURCE: replacing oven bottom liner for Kenmore oven
about to do the same for a friend - hers has two visible screws through the floor at the back of the oven. the new plate has several additional holes. i have not yet removed the old, but looking at other google entries, i may just need to take out the visible screws.
not sure of the model, but it is a free-standing kenmore gas range.
gary
Posted on Jun 06, 2010
I would like instructions on how to use the self cleaning oven on hot point electric stove
Margaret if you read many posts here I really feel using the self cleaning mode on most makes will cause more problems for you . they get too hot and melt solder joints and burn things out .
Nov 23, 2016 | Ovens
One of my burners just started to fizzle and flow extremely brightly. It looks like there are little bubbles on it.
ths burner is having a melt down and if it hasn't burned out it will . replace it / some burners can act like a sparkler and burn till it wll damage the oven surface . so I would just replace . mm
Jul 12, 2010 | Whirlpool RBS275PD Electric Single Oven
About 3am this morning our oven started beeping and woke us up. When we went to see what was wrong the oven display window has and F1 notation. What does this mean?
and also do this
Hello there :
this F 1 error that you are getting is caused by a controle board that may be failing on you what you can do is to unplug it for 30 minutes and during this time open the back of the controle panel and look to see if you see any wires that are burned or shorted out if nothing is found than
to this also open the back access panel to make sure you don't have a grounded element or hot wire melted into another wire to cause a always on condition
i would replace the controle board ok
Jan 19, 2010 | Kenmore Ovens
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Melted aluminum foil
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Good Luck!!
Thanks
Dec 15, 2008 | Kenmore 33169 Gas Single Oven
Melted foil in oven
try this take them out if the oven they just unplug in the back soak them in a de greaser with lemon juice really hot water let me know if this works
Dec 04, 2008 | Dacor MCS130 Millennia Electric Single...
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
23 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
