Question about Motorola Talkabout FR60 (14 Channels) 2-Way Radio
I can talk but cannot hear on the walkie talkie
Neto
  • 123 Answers
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
Posted on Dec 12, 2006
xMadx
  • 64 Answers
SOURCE: walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Posted on Feb 04, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: I have 4 motorola walkie talkies but no
The Motorola GP340 radio is a dealer programmable radio. It requires a cable, radio interface box and Motorola proprietary software (which is available by subscription to dealers and qualifying entities).
Posted on Oct 13, 2009
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
I have a Motorola Talkabout from 1998 that has a talk button, a monitor button, and a power button. Whenever I press the talk button it just says the channel....but when I talk through my other walkie...
It seems a small hardware-problem, like a button is sticking, making a continues connection. If you are comfortable in hardware-modifications, try to open the casing of the malfunctioning walkie talkie. Do this carefully, not to damage it further.
When opened, check the 3 buttons to see any damage, or undesired connections (caused by extensive use or plain dirt).
Oct 14, 2013 | Radio Communications
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Feb 28, 2010 | BellSouth 1061 (14 Channels) 2-Way Radio
Eddie Bauer EBC 530 walkie talkie. What do the
The PTT is your Push-To-Talk button.
Oct 22, 2009 | Radio Communications
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Talking
See if the one radio that doesn't hear the other has a PL tone programmed into it. If both radios are not programmed to the same PL tone, then one will not hear the other. Consult your owner's manual on how to do this.
Regards,
Longshorts.
Jun 24, 2009 | Motorola Walkie Talkie 2-Way Radio
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Walky talky
Cell phone
Feb 04, 2008 | Motorola Walkie Talkie 2-Way Radio
Motorola Talkabout FR60 (14 Channels) 2-Way Radio Logo
53 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
