Question about Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
Putting the hose to vacum - Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum
  • john Dec 14, 2012
    Thank you
  • Dyson Master
  • 18,392 Answers
How to unclog vacum. overheats and cuts off
Check all the filters, put a new bag in or wash the cloth bag, check the outlet filter (if it has one) is also clean. If it still cuts out , there could be a problem with the motor. If the unit has a hose, take the hose off and try it again, the hose may be blocked.
Nov 20, 2016 | Vacuums
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
How can i remove the dust from vacum hose?
If you can take it apart and remove the hose then I would flush it with a hose with a nozzle. I would also spray the inside of the hose with an all purpose spray.
Jul 21, 2012 | Bissell Vacuums
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
The suction isn't working. It is there, but wehn
Check hose to see if it is clogged. ALSO MAKE SURE ALL THE COMPARTMENTS ARE PUT BACK CORRECTLY.If the water resevoir isn't sitting correctly , you will lose suction. Check that hoses are corect as well.
Dec 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dyson DC17 Found the clog-how do I unclog it?
poke it out with a screwdriver this will dislodge the hair it might take a while to get it all out
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Jan 03, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dyson DC11 All Floors Bagless Canister Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
