Question about Hoover Tempo Widepath Upright Vacuum - Blue
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Suction stopped. Roller and belt working-in fine order. Checked hoses, removed at half point with screwdriver and checked "foot"-have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Turned over while on and feels like air blowing out. Help!
  • Kate Dec 11, 2012
    I took off the bottom & 4 screws, re-set roller and big hunks of dust came off from underneath. I checked the bag and made sure the cover over bag "clicked" in place. That worked!
    Top Expert:
  • 14,553 Answers
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Posted on Dec 11, 2012
2 Suggested Answers
renevacdoc
  • 84 Answers
SOURCE: its not sucking up the water off the carpet
Hello. Take out your recovery tank, remove the lid, and re-attach lid rolling it from the front to the back, there are two tabs on the tank that the lid has to be aligned with, you will hear it "click" when it is tight. I think this might be the trick! Let me Know if I helped. Thank you. Rene (The Vacuum Doctor) Don't forget to have your unit serviced once a year by a qualified tech!
Posted on Nov 06, 2009
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
Eureka vaccuum blowing out and not sucking in
Hi There,
I am going to assume you are talking about a Eureka upright vacuum.
The cause for this is generally either
A) Broken Belt - Which you can easily fix by changing belt
or
B) Blockage in the hose somewhere - Basically test the suction with the machine turned on with you attachment hose and see if you have suction. If you do check the belt and make sure you clear out any muck left around the roller.
If you need Eureka vacuum belts go to VacuumSpot.com.au
May 13, 2012 | Vacuums
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kenmore upright progrssive intell clean. For some reason it isn't sucking when I use it to vacuum. When I use attachments they work fine, but when I plug the hose back in after using the...
You have the answer and just don't know it. You are there so keep looking. Somewhere between where the suction hose connects with the lower hose and the power-head. There is a blockage, you may need to turn the unit upside down and look there or try using a wire with a hook on one end, to extract the blockage. but something is blocking the tube from letting air and debris from traveling up the tube.
May 01, 2010 | Kenmore 31913 Progressive Direct Drive...
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No hose suction with pole???
Check the blockage area which can be found on the canister left side of the machine when looking at the machine from the front
hope that helps
Aug 16, 2009 | Dyson DCO7 Animal Bagless Upright Cyclonic...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
Jan 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Won't suck, just blows
it has a blockage - you will have to find it - probably in hose leading away from roller
Mar 18, 2007 | Kenmore 32734 Upright Vacuum
Hoover Tempo Widepath Upright Vacuum - Blue Logo
202 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
